Post by Fossilman on Sept 18, 2012 15:34:24 GMT -5
A couple months ago,I was hunting fossils on the Lost Creek beach south of Newport. I found a huge chunk of pressed sand formation(size of a basketball) that had fossil shells embedded into it that were whole. (Thought I had a pic of it,but I don't)...I worked on it for two months,chipping and spraying hardner on the shells. Finally today I became brave and gave the last wack with my chisel! It loosened the shells right where I wanted them to let go..... Gave them the final coating of sealer and here they are... 175 million year old shells......(Four inch shells)
Post by rockrookie on Sept 18, 2012 17:39:00 GMT -5
Wow !!!!! awesome shells !!
Post by talkingstones on Sept 18, 2012 20:19:43 GMT -5
Those are incredible!!!!!! Great job and congratulations!!!! That took a lot of patience but, wow, was it worth it. Thanks for the share on this but I'm calling you on not putting up a goosebump warning! LOL! Excellent work!!!
Cathy
Post by beefjello on Sept 19, 2012 8:20:45 GMT -5
Great finds!!
steveo
Member since October 2011
Post by steveo on Sept 19, 2012 8:37:13 GMT -5
You did a very nice job fossilman.
Post by Hard Rock Cafe on Sept 19, 2012 15:21:40 GMT -5
Very nice! What do you use for hardener? I've used watered-down white glue, but I'm wondering if there is something better...
Post by Fossilman on Sept 19, 2012 20:45:25 GMT -5
I have been using spray on lacquer....I spray a couple coats on the fossil itself,let it dry,work the metric from the fossil,then give the fossil one more coat....... Works so far......Man these shells are fragile too!!!
elizabeth
Member since August 2011
Post by elizabeth on Sept 27, 2012 12:21:39 GMT -5
What kind of sealer do you use?
Janet
Post by Fossilman on Sept 27, 2012 14:08:19 GMT -5
What kind of sealer do you use? Janet No sealer,just lacquer..........
