garock
Member since February 2006
Post by garock on Sept 30, 2012 10:56:10 GMT -5
bushmanbilly
Member since October 2008
Post by bushmanbilly on Sept 30, 2012 11:35:53 GMT -5
Why are you surprised? Barry has to help all his relatives in the brotherhood. I just wish the leaders of the free world would just walk away from the middle east. Let them fight each other and may the best Camel win. Then step in and give them a choice. Peace or we will bomb you into the stoneage. I say turn there land into GLASS.
itsandbits
Member since March 2012
Post by itsandbits on Sept 30, 2012 13:16:18 GMT -5
and what are you going to throw at them; spent fuel rods from a nuclear reactor? Or are you going to find a way to detonate the ones we sold them? Now that would be devious :<))))
bushmanbilly
Post by bushmanbilly on Sept 30, 2012 13:38:26 GMT -5
Send them a bouquet of daisy cutters to the main palace.
The BLU-82B or “Daisy Cutter” is the largest conventional bomb in existence and is 17 feet long and 5 feet in diameter, about the size of a Volkswagen Beetle but much heavier. It contains 12,600 pounds of GX slurry (ammonium nitrate, aluminum powder, and polystyrene), and is so bulky that it cannot even be launched in a conventional method. To put that in context, the ammonium nitrate in just one Daisy Cutter bomb is about six times the amount used in the bombing of the federal building in Oklahoma City. Although the blast from this bomb is extremely lethal, it still has less than a thousandth the destructive power of the atomic bomb used on Hiroshima. Because of the cumbersome size of the Daisy Cutter and its deadly results, it must be uniquely deployed and detonated. It is launched on a delivery trolley and forced out the back of a C-130 cargo plane. The plane itself must be at least 6,000 feet off the ground to avoid the bomb’s massive shock wave. Once clear of the plane, the Daisy Cutter releases its own parachute. Attached to one end of the bomb is a three-foot long conical probe. When this probe touches the ground the bomb is detonated. Because the bomb is detonated before the majority of it hits the ground basically no crater results. However, the bomb still inflicts heavy damage, generating pressures in excess of 1,000 pounds per square inch near the point of impact, and the shock waves can be felt miles away.
Post by Fossilman on Sept 30, 2012 14:57:27 GMT -5
A nice glass parking lot-enough said!
Post by helens on Oct 1, 2012 1:51:59 GMT -5
