blackout5783
Post by blackout5783 on Oct 20, 2012 23:14:37 GMT -5
So I picked up a Beacon Star 2 wheel grinder for a steal earlier this month and just got to setting it up. I pulled a motor off of an old band saw that I had sitting around for the better part of a year. Motor bolted to bracket - check Grinder bolted to bench - check Motor bracket bolted to bench - check I fired her up and...the wheels are spinning backwards. Crud. I would have a lot more to say, but this is a family board...
Post by quartz on Oct 21, 2012 23:08:34 GMT -5
Don't know about your bandsaw motor, my Craftsman is reverseable, look at tag on motor housing or for one on inside of wiring connection cover for info on rotational setup with the wiring.
Post by mohs on Oct 22, 2012 0:14:37 GMT -5
O bummer that's one I've never done, yet Ha Ha hopefully its reversible or it different motor time good luck connect the ground ! Ed
blackout5783
Post by blackout5783 on Oct 22, 2012 7:51:19 GMT -5
Actually fixed this last night. Just turned the bracket and motor around to drive the belt from the other side. Now, can anyone recommend a good wood putty? I have a few holes in a bench to fill...
zarguy
Member since December 2005
Post by zarguy on Oct 25, 2012 17:05:15 GMT -5
I fill holes like that with a wooden dowel & glue.
Lynn
Post by johnjsgems on Oct 31, 2012 8:22:49 GMT -5
Most reversible motors will have a red and black lead in terminal section. They will be slip on type connections. Just switch the positions.
Post by gr on Oct 31, 2012 11:48:23 GMT -5
Try reversing the leads and then you won't have to fill the holes. Pictures!?
