riverrock
Member since April 2010
Post by riverrock on Oct 23, 2012 6:39:23 GMT -5
Hello to all just wanted to know if you tumble Quartz the same as regular stone. I have someone you has 26 acres of it.
Post by Drummond Island Rocks on Oct 23, 2012 7:03:10 GMT -5
yep, as long as you are tumbling full loads of just quartz it tumbles great. You can mix in others form the quartz family like amethyst and citrine too. here's a few pics from a quartz mix we did in a regular 3lb rotary. Chuck
keystonecops
Member since October 2010
Post by keystonecops on Oct 23, 2012 8:48:48 GMT -5
That is sweet Chuck. Later Clyde
Mattatya
Member since June 2012
Post by Mattatya on Oct 23, 2012 16:36:48 GMT -5
I'm tumbling mixed quartz currently here is a pic of stage 1 for a week (right barrel I had a little oops when checking on them basically dropped both barrels lol. Going back to step one for more shaping. This is my first try with them on a 12# barrel, but I would suggest cushioning after step one to keep your levels right and if you see one looking like it could be break through step 2 3 & 4 pull it out, break it and save it for another batch of step 1. I tied with the a small 3# barrel and one fractured on I should have pulled broke on pre polis stage and wrecked the batch scratching them all up. That's a lot of quartz your friend has. You'll find the best of the best for your batch. Great luck to you. Sent from my SPH-D710 using proboards Attachments:
Post by Jugglerguy on Oct 23, 2012 16:39:24 GMT -5
I've had good luck with quartz. I roughed mine in a rotary and finished it in a vibe. I mixed rocks like Chucks with local quartz that I collected myself. The following pictures have the two types separated, but I tumbled them together. Some of my local rocks were probably not quartz, but most were.
riverrock
Post by riverrock on Oct 24, 2012 8:10:17 GMT -5
So i will treat it just like amethyst , i did not know they were in the quartz family.
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Oct 25, 2012 15:09:56 GMT -5
I have someone you has 26 acres of it. YO YO !!!!! Quartz Par-Tay at riverrocks place !!!!! or at his friends... I'll bring the grit and beer... umm I mean water!!!! :blush: seriously ?? 20 +/- acres?? Tell your friend... "lets get them MFRB's going "!!!!!
