Post by phil on Oct 28, 2012 15:00:22 GMT -5
Ok. Need some advice here. I want to polish some turquoise, and will be polishing small lots, maybe 3 or 4 pounds. So, Ok, I know I need the smaller unit. But which vibratory unit should I go with? Raytech or Thumbler? Anyone out there with experience doing these stones that can give me some advice? Thanks! Phil
Post by Jugglerguy on Oct 28, 2012 20:39:18 GMT -5
I don't know anything about turquoise, but you've left a good vibratory tumbler off your list. I have a Lot-O and I really like it. It holds about 4 pounds, which seems like just what you want. I have no experience with Raytech or Thumler, so I can't comment on them.
Post by Bikerrandy on Oct 28, 2012 21:14:49 GMT -5
Can turquoise be tumbled? I thought that it was too soft.
Post by johnjsgems on Oct 28, 2012 21:31:43 GMT -5
If it is stabilized it will tumble just fine. Gy-Roc is another great vibe tumbler to consider. I sell them but only started using one last week. They work very well. The DP Mini Sonic is also very good. I would drop Raytech from your list.
Post by johnjsgems on Oct 28, 2012 21:35:41 GMT -5
By the way, I tumbled some stabilized turquoise a long time ago and the shine was only satin. I ran it in 25,000 Vibra Dry and it got too shiny. It looked like plastic, fake turquoise. Whatever tumbler you decide on watch it closer than you would agate.
Post by phil on Nov 2, 2012 11:04:19 GMT -5
Thanks all.
Yeah John, I know about the satin. But I plan on freeform preshaping on a 100 grit wheel, then tumbling to the satin stage and finishing on a slightly moist oxide (probably tin) leather disk. I usually get a wowser shine that way. I avoid turquoise that is bland and has no character so a high polish works best. Material like Sleeping Beauty all blue does look like plastic to me too.
