Post by jamesp on Nov 4, 2012 19:49:24 GMT -5
No more 8 and 16 grit for me.It has been ground with the surface of the rock.This is heat treated Savannah River agate and it is full of small botroidal lined cavities.About 30 percent have grit wedged in them.
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Nov 4, 2012 19:51:09 GMT -5
OUCH !!!!
I feel for ya James!!
Still trying to put together a trip to get some savannah for myself... hopefully soon!!
Post by Drummond Island Rocks on Nov 4, 2012 19:58:30 GMT -5
Bummer, hope you can salvage those. I have a set of real sharp picks I use when 60/90 gets stuck in rocks but those look like the grit is about the same size as the holes they are in.
Post by jamesp on Nov 4, 2012 20:12:16 GMT -5
You must go there Mario.It is very quiet,in big farm country.Wnen you get to the boat ramp artifacts are in the river gravel for about 200 yards on the upstream side.But the river has to be low.I may have cleaned them all out over the years.Mostly flint tools more so than points.
That is a bummer.I will see what happens if i leave them in there.What may happen?
Thunder69
Thunder 2000-2015
Post by Thunder69 on Nov 4, 2012 20:41:50 GMT -5
Why not try a small diamod drill bit...Might work....John
Post by quartz on Nov 4, 2012 21:37:45 GMT -5
I have the same situation at times, a sharpened motorcycle spoke works well as a pick. That is some really nice rock. Larry
Post by jamesp on Nov 4, 2012 21:40:52 GMT -5
The diamond bit sounds like the way.Thanks John
Dora
Post by Dora on Nov 4, 2012 22:13:25 GMT -5
Ugh, what about tumbling them in soapy water, might work on some.
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Nov 4, 2012 22:33:55 GMT -5
16 grit? That's bigger than some of the rock I tumble!
The Dad_Ohs
Post by The Dad_Ohs on Nov 4, 2012 23:30:26 GMT -5
If you leave it in there you run the risk it will pop out during a later tumble or even during polish and ruin the entire batch, I would go after them with a tiny diamond burr or drill and see about removing them, then run them through the 36 and hope for the best!!
Tomorrow I check on my Lakers that have been in course & medium for a week to see how they are doing.
Post by Deleted on Nov 4, 2012 23:47:53 GMT -5
try putting them in an ultrasonic cleaner with hot water and dawn dish washing liquid. If you don't have an ultrasonic cleaner, Harbor Freight does for about $30.
