Post by stardiamond on Nov 25, 2012 15:22:25 GMT -5
Montana Some kind of Owyhee Sheep Creek Morrisonite
pporky
Member since May 2007
Post by pporky on Nov 25, 2012 15:51:28 GMT -5
Nice pieces, I especially like the owyhee piece , I am not familiar with the term buff tops may somebody enlighten me on that one please.
Post by mohs on Nov 25, 2012 15:57:05 GMT -5
I just got drove in from the heat here and those are hot rocks indeed Ed
Post by stardiamond on Nov 25, 2012 16:15:11 GMT -5
Nice pieces, I especially like the owyhee piece , I am not familiar with the term buff tops may somebody enlighten me on that one please. Buff top means there is no doming, only the face is polished. I cut buff tops when, I think the pattern on the face will change if it is ground down. I also do it when working with thin slabs. The down side is it is more difficult to remove scratches and the top and bottom need to be aligned. Normally I set the shape on the bottom and dome toward the center.
Post by Bejewelme on Nov 25, 2012 16:32:05 GMT -5
That owyhee almost looks like intarsia with the patterns, I like that one!
Post by FrogAndBearCreations on Nov 25, 2012 17:33:04 GMT -5
Nice batch!
Post by frane on Nov 25, 2012 17:38:35 GMT -5
you have a great batch here. That unknown looks like some sheep creek that I have. Fran
RocknCritter
Member since November 2008
Post by RocknCritter on Nov 25, 2012 18:06:29 GMT -5
Buff top means there is no doming, only the face is polished. I cut buff tops when, I think the pattern on the face will change if it is ground down. I also do it when working with thin slabs. The down side is it is more difficult to remove scratches and the top and bottom need to be aligned. Normally I set the shape on the bottom and dome toward the center. Nice cabs! FYI: In the jewelry trade, the generally accepted definition of buff top can be found here www.merriam-webster.com/dictionary/buff%20top"a style of cut of certain gemstones in which the top is cut cabochon and the bottom is step-cut"Either way, all the cabs can all be called pretty
Post by Pat on Nov 25, 2012 18:36:29 GMT -5
I didn't know what "buff top" meant either. Thanks for both the explanations.
Post by talkingstones on Nov 25, 2012 19:17:23 GMT -5
All are beautiful but the morrisonite is my favorite! Almost looks like it's glowing in spots!
Cathy
Post by stardiamond on Nov 26, 2012 0:22:18 GMT -5
you have a great batch here. That unknown looks like some sheep creek that I have. Fran I think you are right. I know I have some, but after a while it is hard to remember what slabs you have. I'll change the description on this topic.
