Post by phil on Dec 1, 2012 11:09:37 GMT -5
That little depression in the bottom of the bowls gets clogged with hard grit. Is it OK to fill it with GE Silicone II or will that affect the action adversely?
Thanks.
Post by geoff on Dec 1, 2012 11:17:01 GMT -5
Yep. That's what I filled mine with. It's from manufacturing and serves no purpose. Just make sure it's good and clean, then fill it up and let it cure. I've seen no wear on the silicone in over a year of constant tumbling.
Post by phil on Dec 1, 2012 11:18:34 GMT -5
Thanks
Can small (it it fits thru the opening) flat slabs be polished in a Lot-O?
Phil
cardiobill
Member since March 2012
Post by cardiobill on Dec 1, 2012 12:48:56 GMT -5
I used epoxy on mine. Worked fine Bill
Post by johnjsgems on Dec 1, 2012 13:08:53 GMT -5
You can do small slabs in any rock vibe. You need at least 70% small ceramic filler or lots of small non flat rocks in the mix as a grit carrier and a means of keeping the slabs apart.
Post by phil on Dec 1, 2012 15:09:59 GMT -5
thanks!
Post by jamesp on Dec 12, 2012 7:33:16 GMT -5
Silicone seems to never wear from tumbling.Sticking to pvc or polyethylene may be a challenge
Post by johnjsgems on Dec 12, 2012 9:19:30 GMT -5
Will silicone embed with grit?
