lparker
Member since March 2008
Post by lparker on Dec 8, 2012 18:25:16 GMT -5
I hope these stay on the dops. I haven't dopped in years and thought I'd try again to save my nails. Gonna be a busy day tomorrow.... Attachments:
Post by mohs on Dec 8, 2012 20:56:06 GMT -5
all dopped up & ready to grind! its a beautiful thing! are they glued? good luck ! ST3D
keystonecops
Member since October 2010
Post by keystonecops on Dec 8, 2012 21:34:02 GMT -5
Lee, One o the things I was taught on doppin, after ya get em on the stick, set em somewhere they cool down slow. I put mine on a 2by4. Very rarely do they come off. Couldnt see the back side, gotta be featherd pretty good. Later Clyde
hope
Post by hope on Dec 8, 2012 23:41:43 GMT -5
Those should relieve a lotta stress. Have fun.
Hope
pporky
Member since May 2007
Post by pporky on Dec 9, 2012 1:25:43 GMT -5
Looks like a fun day
Post by talkingstones on Dec 9, 2012 7:41:57 GMT -5
Looks great and like you certainly do have a busy day ahead! Enjoy the day as it looks to be a good one!
Cathy
Post by beefjello on Dec 9, 2012 7:55:16 GMT -5
You literally have your work cut out for you Looks like a fun day ahead Lee!
Post by frane on Dec 9, 2012 8:35:56 GMT -5
I need to dop some more of mine. I tend to skip it and then sometimes have a problem with getting them completely even. Looks like you are ready to go! Looking forward to seeing the finished batch! Fran
hubrocks
Member since April 2011
Post by hubrocks on Dec 9, 2012 15:02:49 GMT -5
That looks like fun!! too cold in my garage to cab buurrrrr!
Post by Pat on Dec 9, 2012 15:05:59 GMT -5
Busy, and fun day!
lparker
Post by lparker on Dec 9, 2012 17:10:57 GMT -5
Done and they all stayed on the stick (super glue). Now to get them off and the glue off the backs. Attachments:
lparker
Post by lparker on Dec 11, 2012 10:21:33 GMT -5
AArgghhh! Did a good job dopping them. Put them in the freezer over night and they popped right off the dop sticks - NOT! Gotta get some acetone
Post by mohs on Dec 11, 2012 10:52:24 GMT -5
a trick I learned from gr is if they are super glued on wood dowel soak them in water over night the stick expands a lets loose good luck ed
lparker
Post by lparker on Dec 11, 2012 19:54:05 GMT -5
OK, I'll try that first...a little less toxic. Thanks.
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Dec 11, 2012 19:59:04 GMT -5
If that doesn't work, you could try using a box cutter safety blade and gently rock it back & forth between the stone and glue. It should remove most of the glue when it separates from the stone. I used that method with other things, haven't done much cabbing with dop sticks yet though.
jspencer
Member since March 2011
Post by jspencer on Dec 11, 2012 23:07:55 GMT -5
I found that super glue will hold like nothing else can match. But who wants to soak a soft stone in acetone. Even after soaking for a couple of hours I had hell. Broke 1 cab getting it off. I use green dop wax instead. Be sure to preheat the stone really well before applying the stick with wad of wax to the cab. Return it to continue heating to complete the bond making sure to feather it out with your fingers before removing it to cool at room temp. 10 mins. in the freezer and they pop right off the stick. I learned to bag mine before freezing after a couple dropped off the stick in mid air as I was pulling them out.
lparker
Post by lparker on Dec 12, 2012 13:41:12 GMT -5
Soaking in water worked great with all but three...my massive butcher knife took care of those. I had one break on a fault line...not bad! Now to dry the dowels, sand the glue ends, preform some more cabs, and do it again. Oh, and get the glue off the finished cabs. Attachments:
Post by drocknut on Dec 12, 2012 13:58:35 GMT -5
Glad you got them all off but isn't the butcher knife a bit of overkill? LOL Oh wait, this is Lee we are talking to...;-)
lparker
Post by lparker on Dec 12, 2012 15:36:28 GMT -5
Yup, no sense going half-way Was so much fun I might do the whole next batch that way....I'd get a faster turn-a-round on the sticks.
mossyrockhound
Member since January 2011
Post by mossyrockhound on Dec 12, 2012 18:26:56 GMT -5
Good going - you made uip some nice cabs. Kind of hard to tell what the best dopping method is though. Seems like they either fall off the dop when working them or you can't pry them loose. I used to have no problem dopping, but lately my cabs have been coming loose during the first sanding step.
