roxane
Member since December 2012
Post by roxane on Dec 28, 2012 21:00:40 GMT -5
Hi, I am new, very new to tumbling. Though I have wanted to for years. I received a great Lotone tumbler, rough rock and all the required grits to get started for Xmas....yeah!
My problem is that I appear not to be strong enough to take the outside lid off the barrel. it seals so tight. which is great so there are no leaks, but if I can't get it open I can't tumble anything!!
Will they get easier to remove? Is there any helpful hints to make them easier to remove? Or am I stuck having to wait for my Husband to open for me?
Looking forward to your help and years of Rock talk to come
Roxane (Rocky)
Post by tntmom on Dec 28, 2012 21:18:32 GMT -5
Hi Rocky!
Use your thumbs and every inch or so on the barrel, just beneath the lid, push real hard. Go around the entire barrel doing that and you will loosen the seal that has vacuumed on during the tumbling process. Even after that.... if it's really stubborn, a gentle nudge up with a flat head screw driver can also help break the vacuum. It should be able to remove easily after that.
cardiobill
Member since March 2012
Post by cardiobill on Dec 28, 2012 21:33:10 GMT -5
If you are having trouble with the metal piece then use the washer on the lid to pry it off Bill
Post by phil on Dec 28, 2012 21:41:45 GMT -5
I always have to squeeze the sides to get it off. I tried a little vaseline, it didn't seem to help.
Post by Drummond Island Rocks on Dec 28, 2012 22:04:34 GMT -5
I always use the washer and wedge it in the small gap at the bottom edge of the metal lid and twist to release my lids. Works every time.
Geoff
Please add 1074 to my post number.
Post by Geoff on Dec 28, 2012 22:05:11 GMT -5
Loosen the nut, but don't remove it. Set the barrel on the table and push down on the nut. Always pops the metal lid loose for me.
marinedad
Member since December 2010
Post by marinedad on Dec 28, 2012 22:56:07 GMT -5
i always use the washer myself to pry lid off.
herchenx
Member since January 2012
Post by herchenx on Dec 29, 2012 13:30:27 GMT -5
Yep, as said metal washer pries the aluminum lid off, then slowly work the rubber edge away from the rubber gasket/lid thing until you can pop it out.
roxane
Post by roxane on Dec 29, 2012 14:24:46 GMT -5
thanks everyone....I will try these hints....happy tumbling and happy new year to all
metalsmith
Post by metalsmith on Dec 29, 2012 17:28:38 GMT -5
The vacuum will be a partial vacuum - otherwise you would never get it off. This happens to me a lot because I load it in the house (warm) and then tumble in the workroom (cold) so the air contracts. Take it into the warm or actively warm it a little to cause the air inside to expand. Presto!
roxane
Post by roxane on Dec 29, 2012 19:20:46 GMT -5
thanks for all your help everyone...I've gotten it open so now I know and I no longer need to wait for my husband.....I get impatient, and want to see now!!!
Roxane (Rocky)
cherdarock
Post by cherdarock on Dec 29, 2012 20:40:33 GMT -5
Them girls, my wife says the same thing! "I WANT TO SEE IT, I WANT TO SEE IT!!! ... ooooohhhhh, looook... look at THIS one..."
Dora
Member since September 2012
Post by Dora on Dec 30, 2012 4:08:39 GMT -5
Hello Roxane and Welcome! I have that problem often, so my technique is to gently press/squeeze the middle of the rubber barrel and the lid comes out more easily.
Post by NM Stone Supply on Dec 30, 2012 9:31:23 GMT -5
Roxane, now when you put the first lid back on make sure the barrel and edge of the lid are clean. Grit and pellets collect in the little notch and if there is enough the barrel can leak a little bit. I just wipe the edges down with a paper towel. Jason
