tjmax
Member since March 2004
Post by tjmax on Apr 8, 2004 21:27:05 GMT -5
I totaly forgot i had a sniper bid on the Mini-Sonic duel 4 pound Tumbler for 2 dollars over the current bid and i won it Ohh well, i can always try it out and resell it if i don't want it.
MichiganRocks
"I wasn't born to follow."
Member since April 2007
Post by MichiganRocks on Apr 8, 2004 21:41:47 GMT -5
Based on what it says and shows, I don't how you can go wrong with that buy. That is a lot of stuff for $97! The Mini-Sonic is supposed to be a very durable unit.
Post by docone31 on Apr 8, 2004 21:42:52 GMT -5
I bought a faceter and it came with a tumbler. The owner thought it was broken. It needed a fuse, and both bbls were full of emeralds, rubies, saphires. I did not know they were tough to polish and they were the reason I found this forum. Sometimes things work out in interesting ways that bear unknown fruit. Perhaps your oops will have the same effect for you.
tjmax
Post by tjmax on Apr 9, 2004 3:34:39 GMT -5
Ohh i am not upset about it actually, it was a hell of a bargin 97 bucks for a what 300 dollar tumber unit. I could turn around and list it properly and make a profit most likely. But i will keep it for now and find out what one works the best.
tjmax
Post by tjmax on Apr 14, 2004 8:09:54 GMT -5
OK, already i am REALLLLLLY liking this tumbler, The rocks rotation action is much more fluid compaired to the Raytech's Tumble-Vibe 5.
I don't see where first grind would be an issue at all with this type of tumbler or even grit courseness. First grind on a TV-5 is very hard. TV5 tends to flatten out some stones as they don't rotate unrounded stones very well. This tumbler they never sit still long enough to flatten anything. I can see how this tumbler would easly cut the time of polishing too. I don't intend on doing any first gind in this tumbler, i plan on using one hopper for prepolish one hopper for polish and doing all first grinds in a rotory tumbler.
MichiganRocks
Post by MichiganRocks on Apr 27, 2004 16:27:09 GMT -5
Hey tj, how are things going with your Mini-Sonic? I'm anxious to hear how things work. Is it quieter than your TV-5?
Ron
