meta7
Member since June 2010
Post by meta7 on Jan 2, 2013 15:45:31 GMT -5
I am working on Metamorphosis Quartz pieces (1-3 pound pieces) and I find that sometimes little chunks break off the pieces when I use coarse grinding wheels such as 60-100.
When I use a 220 wheel, this does not happen, but it obviously takes a lot longer to grind down the rock with a 220 as opposed to a 100.
Does anyone have experience using diamond grinding wheels in the 120-180 grit range? Is there a grit that would not be too harsh on these fragile quartz pieces, yet would perform faster than 220 would?
I am using 8" wheels.
Thanks, :-) Dave
Post by Rockoonz on Jan 2, 2013 23:17:34 GMT -5
Try a 180 if you can find one reasonably. If I recall correctly I either use a well used 100 grit or a 180 flat lap to start when working with quartz points. What makes Metamorphosis quartz unique?
Lee
Post by mohs on Jan 2, 2013 23:45:17 GMT -5
sanding belt? I have one in 60 grit with the rubber backing it might be gentler
Post by Deleted on Jan 3, 2013 12:12:44 GMT -5
I go to 200 and take the extra time but I am never doing large quantities either. One to three pound pieces are pretty large. Are you just windowing? Holding a three pound piece up for any length of time has to be pretty tiring. Pictures? Curiosity killed the old man you know. Jim
meta7
Post by meta7 on Jan 3, 2013 23:30:27 GMT -5
I am not windowing, I am working the entire piece. I will have to find my camera and get some good lighting and take some pictures.
I will have to try a 180 hard metal diamond grinding wheel, and see if it is quicker than the 220.
And, for me at least, working with 1-3 pound pieces is not a big deal at all. Maybe I am used to it. I just know that when I work on 5-10 pound pieces, then my bicepts get tired quickly and I have to take breaks every 2 minutes or so.
Metamorphosis quartz is special, both from a Metaphysical perspective, and also because it affects Light in 9 different ways. I can't remeber the names, except for asterism, but it has a nice glow and subtle optical effects when held and/or cut from different angles.
Post by jamesp on Jan 6, 2013 13:48:09 GMT -5
Belts always smooth more gentle.
Post by gingerkid on Jan 9, 2013 15:55:54 GMT -5
Have you had a chance to work the quartz with a 180 grit diamond wheel yet? Read that metamorphosis quartz is trademarked and similar to girasol quartz? Would love to see a pic of it if you would please post one, meta7.
Have a concave faceted girasol quartz that is really pretty. It has a glowing appearance to it similar to moonstone and nice dispersion when light hits the stone at different angles.
