custommike
Member since November 2012
Post by custommike on Mar 31, 2013 14:31:44 GMT -5
Are the alb barrel pretty much the same size? The rubber gasket that covers the barrel lid on one of my barrels wore through. Just wondering if I need to get a vendor specific part or if any 3 lb barrel part will work.
Thanks
Mike
Post by susand24224 on Mar 31, 2013 23:25:00 GMT -5
What size barrel? My (limited) experience is that the dimensions vary more significantly as barrel size increases.
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Apr 1, 2013 18:50:08 GMT -5
Mike, what brand 3 lb barrel do you have that's needs a new lid gasket?
tkvancil
Member since September 2011
Post by tkvancil on Apr 2, 2013 11:48:45 GMT -5
I have 2 Lortone 33b's & a 3# Chicago Electric. I know a Lortone lid liner works on the CE if you stretch it a bit. These two manufacturers barrels are slightly different although both 3 pounders. I suspect it is best to use replacement parts from the specific brand.
Post by johnjsgems on Apr 2, 2013 11:59:59 GMT -5
Chicago is a Lortone copy so pretty close. Thumlers is completely different design.
custommike
Post by custommike on Apr 14, 2013 17:09:55 GMT -5
I have a Chicago double barrel 3lb currently running with a single barrel 3lb sitting idle due to a leaking gasket
Minnesota Daniel
A COUPLE LAKERS
Post by Minnesota Daniel on Apr 14, 2013 21:05:11 GMT -5
Look for a Chicago brand replacement gasket. They have an online catalog don't they? You should be able to order and have it mailed right to you.
