Post by doneall517 on Apr 12, 2013 22:56:22 GMT -5
was wondering if anyone has used the dual tub Lot-o tumbler and what one's thoughts were about it? Is it better to have two seperate tumblers? Mike
Geoff
Please add 1074 to my post number.
Member since December 2012
Post by Geoff on Apr 12, 2013 23:07:30 GMT -5
If you have enough material to keep both barrels full it's great. I have a single and a double. I have 20 pounds worth of rotary tumblers running 24/7 to feed them. I'm only able to run the Lot-Os 2 weeks at a time as I work in Prudhoe Bay 2 weeks on, 2 weeks off. I also preform 1-2 pounds of cabs a week. Even with all of that, I rarely have enough material to keep all three running for the entire two weeks.
Post by Jugglerguy on Apr 13, 2013 11:38:32 GMT -5
I don't have a dual Lot-O, only a single. You have to have both barrels full to run the dual, or you could damage it. I have a total of 18 lbs. capacity in rotary tumblers and my single Lot-O sits idle most of the time.
Post by doneall517 on Apr 13, 2013 16:52:47 GMT -5
I did not think about having to rub both barrels. Guess that means a couple of single's are in the future. Thanks Mike
