Post by christopherl1234 on Apr 30, 2013 14:45:46 GMT -5
I finished this one up last night. I cut it from the material I recently dug at our claim the JEBEREDHIAH. ![](http://i397.photobucket.com/albums/pp59/christopherlesso/Fire%20Agate%20Cabocons/281mmx142mmx67mm201ct25-5_zpsf6e8cd60.jpg) ![](http://i397.photobucket.com/albums/pp59/christopherlesso/Fire%20Agate%20Cabocons/281mmx142mmx67mm201ct25-3_zps4c61a26d.jpg) ![](http://i397.photobucket.com/albums/pp59/christopherlesso/Fire%20Agate%20Cabocons/281mmx142mmx67mm201ct25-2_zps6a00a358.jpg) Thanks for looking, Christopher
Post by christopherl1234 on Apr 30, 2013 14:47:32 GMT -5
I am not sure why these photos are not showing up here. Someone told me once about removing something from the Photobucket link before posting but I forgot. It was working fine yesterday. I wonder why it changes.
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Apr 30, 2013 15:11:52 GMT -5
photobucket is such a mess these days. PB hosted images still don't work on my default smartphone web browser. had to install the FF app. wish they'd get their act together; seems like a crapshoot if a PB hosted image is going to work.
Post by christopherl1234 on Apr 30, 2013 15:50:32 GMT -5
Funny....they post fine at the gemstone board.
Post by FrogAndBearCreations on Apr 30, 2013 16:04:50 GMT -5
well I messed with it and could not get it either
Post by Deleted on Apr 30, 2013 16:13:38 GMT -5
actually the broken images are links that work!
Don
Post by Don on Apr 30, 2013 16:17:25 GMT -5
hmm...no dice. I can't get them to show either.
Post by Deleted on Apr 30, 2013 16:34:38 GMT -5
don, you clicked on it??
I clicked all three and saw a gorgeous cabochon.
Post by Deleted on Apr 30, 2013 16:38:11 GMT -5
OK, Chris. I did some playing around with your images.
I think Photobucket is not allowing remote viewing. They are refusing to serve the image to links on this website. OR this website is not allowing photobucket images to display
Your code is good.
Don
Post by Don on Apr 30, 2013 16:42:18 GMT -5
It's a problem with Pro Boards v4.5. the character string for URLs is limited to 120 characters. the PB urls are over 120 characters. You'll have to run the image urls through a website like tinyurl first and then use the shortened url to imbed the images in your posts here.
The 5.0 update to proboards should resolve this issue when it rolls out with in the next month.
Don
Post by Don on Apr 30, 2013 16:43:25 GMT -5
Post by Deleted on Apr 30, 2013 16:51:07 GMT -5
Post by christopherl1234 on Apr 30, 2013 16:53:45 GMT -5
Hey there it is. Thanks for that!! And clicking on them works too. I wonder why I had no problems with the posts I did yesterday?
I am glad you all know this stuff about codes and strings because I have no idea and not sure if I want to take away from my rocks to learn a new skill. Might have to someday though. I hope not.
Post by Deleted on Apr 30, 2013 17:22:27 GMT -5
Fortunately for some of us rocks is the new skill and we have the coding already covered.
pporky
Member since May 2007
Post by pporky on Apr 30, 2013 17:31:41 GMT -5
Very nice cab and I also clicked on the first ones and was able to also see many more of your fire agates , wow you have some beauties there
Post by orrum on Apr 30, 2013 21:15:44 GMT -5
Thats a very nice cab Chris, I tried fire agate first and gave it up for turquoise and now am into jaspers etc. That fire agate is HARD ROCK!
Post by roy on May 1, 2013 9:02:53 GMT -5
nice looking fire agates i like how you get a clear cab with a floating fire patch those are my fav
rockpickerforever
RIP Jean Bradley, you are forever loved
Member since July 2011
Post by rockpickerforever on May 1, 2013 15:31:00 GMT -5
Agree with Don, it's a problem with the current version of ProBoards, and the long URLs. Hope the update takes care of that little problem. But if it doesn't you can help yourself out by giving your PB albums and photos short names, and also to disable "file name scrambling" for future uploads. Don't change the names of anything you already have links to, as this will make all the photos you've already posted go away!!!
When PB updated, it also changed some of my settings, like the link options. It was giving me both the URL and IMG codes, at the same time, and I had to delete a bunch of it (don't need the URL part). I had to go into my settings, and changed it back to just IMG code. I had to do it twice, but now it is just giving the IMG code. Hooray for small favors...
I think their update screwed up more things than it fixed! Jean
Post by christopherl1234 on May 1, 2013 17:09:07 GMT -5
Jean, I was unable to find the "file name scrambling" nor was I able to figure out how to make it just give me the IMG code in the settings area. How did you do it?
rockpickerforever
Post by rockpickerforever on May 1, 2013 17:59:36 GMT -5
I thought maybe someone would like to know. Okay, I'm going to type this as I walk through it.
Go to PB and sign in. In the upper right, you'll see your login name. Click on that and pull the menu down. Select "User Settings."
Now you are on a page titled "Personal Information." Click on Privacy. There's a large box that says "File Name Scrambling." Underneath where it says "For Future Uploads" uncheck the box, then click Save at the bottom of the page. They recommend that you check it, to "scramble file names to make links hard to guess" but I've found that things go much more smoothly - and codes shorter! - without the scrambling.
Now, to get just the IMG codes. From where you are at, towards the upper left, select "Albums." You will see where it says "Links" at. Unclick everything except IMG Code. I also have the easy linking mode checked, and the link back to albums unchecked. (Not exactly sure what the last one is, just seemed to work better after I unchecked it.) Now click Save at the bottom of the page to save your changes. Don't know why, but the first time I changed it to just IMG, it didn't take effect. So I went back in and checked ALL of the boxes, and hit save. Then I went back and unchecked all the links except IMG again, and then saved it. That time it worked!
I hope this helps! Jean
