Post by stoner on Apr 16, 2004 21:42:01 GMT -5
Does anybody know what Thumler's uses as a pre-polish? I've got a batch coming out of 100/200 and I was going to go straight to 1000 alumna, but if their pre-polish is in between, then I'll use that first. Also, does anybody use just 80g as opposed to 60/90 for the rough grind? Any advantages/disadvantages?
Thanks, Ed
James
Member since October 2003
Post by James on Apr 16, 2004 21:48:22 GMT -5
Thumlers comes standard with Tripoli pre-polish. You wont be needing 1000 grit after tripoli. You only need 1000 after 400 or 500 sc.
James
Post by James on Apr 16, 2004 21:50:30 GMT -5
Oh, the straight grits like 80, 220 ect... are really only nessacary for flat laps and such. Not for tumblers.
Post by stoner on Apr 16, 2004 21:58:36 GMT -5
Hey James. Thanks for the info. The reason I ask about the 80g is cuz the local rock shop I go to was out of 60/90 so I bought some 80, but it doesn't seem to work as well. any thoughts?
James
Post by James on Apr 17, 2004 1:54:39 GMT -5
I think the "60" part of 60/90 might be the reason why. It will most likely make a difference in the grinding power of the grit. Opposed to the 80 grit which is actually closer to 90 then 60 grit.
