Post by apesandmonkeys on May 25, 2013 21:59:30 GMT -5
Hello fellow Tumbling Enthusiasts ! We are going to be tumbling Labradorite soon, in our rotary tumbler, and wanted to find out if there are any tips/recommendations, since Labradorite is a softer stone (although not too soft, like Fluorite). I have read about adding an extra step between the pre-polish and polish, but is there anything else anyone might recommend? Many thanks, Cheers!
Post by quartz on May 26, 2013 1:08:30 GMT -5
Start out w/220
rollingstone
Member since July 2009
Post by rollingstone on May 26, 2013 20:24:20 GMT -5
Here's a recipe I used when I tumbled some quite a few years ago: 60/90 (with pellets) until shaped, about 3 weeks with weekly recharges. 120/220, 8 days 500F, 8 days CPP polish (aluminum oxide), 11 days Use plastic pellets throughout to prevent chipping because all feldspars like to chip along their cleavage planes. Couple of pics of the results: The flash really depends on exact orientation... now you see it: Now you don't...
Post by apesandmonkeys on May 26, 2013 23:40:47 GMT -5
Thank you for the responses thus far! Are there any particular type of pellets that one would recommend? I've seen a few on The Rock Shed, so wanted to make sure I get the best for my Labs
Post by paulshiroma on May 27, 2013 21:34:31 GMT -5
I had a hard time with this one. The orientation was such that if it wasn't right, it wasn't coming out well... at all. Good luck!
Post by apesandmonkeys on May 29, 2013 17:25:47 GMT -5
When adding pellets, how much should one add to the barrel (for a 3lb size)?
