billyd
Member since December 2004
Post by billyd on Jun 20, 2013 11:47:05 GMT -5
hi i am looking for a new 10" saw blade but dont have a lot o cash and stay in scotland where cheap dont last. have noticed that postage from the us is more than the cost of a blade.
Post by jakesrocks on Jun 20, 2013 13:15:29 GMT -5
Post by deb193redux on Jun 20, 2013 14:06:45 GMT -5
that site appears a bit wonky. I cannot make their numbers add up.
the say best 3150 SFPM, but for a 10" (.83 ft) blade that is about 1204 RPM, while most stock pulleys and motors will be at 1750 rpm.
they also say divide 12000 by blade diameter to get RPM, but 12000/.83= 14k RPM. Not. - If you assume an extra zero, and use 1200/.83 you get 1445 RPM, which is different form true value of 1204.
They also say it is a .028" thick blade in the text, but in the pulldown they indicate .034", which is more believable since .032" is a standard size.
I would cross examine them about some of these numbers, and if possible get manufacturer and double check recommended RPM. The webmaster seems a bit sloppy or confused.
Post by Rockoonz on Jun 21, 2013 11:29:50 GMT -5
3" at the motor and 4" at the arbor is 1293. If it's a sintered blade that's an ok speed, but they don't specify what it is. If it's a crimped edge blade the quality isn't there and the price is way too high, and you should be closer to 2500 SFPM.
Lee
billyd
Post by billyd on Jun 23, 2013 11:13:24 GMT -5
thanks for the help. want to get a continuous rim blade,only cut agates with the saw so can anyone recomend what tipe to go for.cheers billy
