Post by orrum on Jul 5, 2013 19:18:33 GMT -5
I bought a old Lortone 4# rotary tumbler from ebag. It came with two grit pack kits. They do not have grit size on them other than course, fine, prepolish, polish. They r in metal cans that u open with a can opener and are stacked up in a carboard folder from the factory. The course and fine gray and I guess are 60/90 and 120/220. The prepolish is white powder and so is the polish. Wonder what these are, I have aquired a used loto vibe and I want to try it out if possible without buying a bunch of grit in case the motor is not good, they r very expensive. I looked up the modern kits and some larger kits have 500 unspecified grit for prepolish and some have 1000 unspecified. I figure some of yall have used these in the past. Is 500 or 600 sc grey? It looks sorta brown in the pics on ebay. Thanks, Bill
Geoff
Please add 1074 to my post number.
Member since December 2012
Post by Geoff on Jul 5, 2013 20:47:54 GMT -5
I would guess 60/90 SiC, 120/220 SiC, 500 AlO, and AlO polish.
Post by johnjsgems on Jul 6, 2013 10:59:53 GMT -5
Lortone uses titanium dioxide as their tumble polish. A good (like .3 micron) aluminum oxide would be the best for a vibe tumbler. Usually the Lortone (and other manufacturer's kits) are about a single load supply for a rotary tumbler. You would not use the 60/90 in a vibe either so unless really low cost not much of a deal.
Post by orrum on Jul 6, 2013 12:30:48 GMT -5
Hey John thanks, can I use the polish I got from u for cabbing? Its .3 micron isnt it? Also do you know what the Lortone prepolish is? Can I use it in the Loto? So would 120-220 then the prepolish then the .3 micron stuff I got from you get the job done ? Thznks, Bill
