meviva
Member since July 2013
Post by meviva on Jul 28, 2013 21:37:31 GMT -5
Is a dremel useful in this rock tumbling hobby? If so, what attachments work the best. Can it cut rock?
Thanks
Post by vegasjames on Jul 28, 2013 21:49:17 GMT -5
There are rotary diamond blades that I have used to cut shell and meteorites. I have seen them in two different sizes.
I also use rotary tools with various diamond burrs to clean other material out of the matrix of rocks.
Post by deb193redux on Jul 28, 2013 21:55:02 GMT -5
some type of diamond ball or drum burr, large size, can help smooth out crevasse or take down thin wedges. but overall not a lot of help. the tools wear, and it adds to the cost. you also need to work wet.
more useful for drilling a hole in finished rock, even moreso with flexshaft. many need collet set or multichuck
can also carve a bit on softer stones. harder ones too but it takes longer and requires better diamond tools.
meviva
Post by meviva on Jul 29, 2013 16:08:49 GMT -5
Thank you. I guess I will try a few things with it and see how it goes.
Post by deb193redux on Jul 29, 2013 16:16:53 GMT -5
what diamond burrs did you get?
meviva
Post by meviva on Jul 29, 2013 21:48:20 GMT -5
The only diamond accessory is a diamond point....it says it's for carving but not drilling. Not sure if that will be useful. I am very new to this so I have absolutely no experience with any of this.
Post by deb193redux on Jul 29, 2013 21:59:46 GMT -5
any grinding accessories besides diamond will not dent agate. you can get braised burrs cheap from jadecarver.com, and sintered ones from $5 to $30 each.
with light touch, 1.5" diamond cutoff can be poor man's lap plate
meviva
Post by meviva on Jul 29, 2013 22:42:48 GMT -5
Thanks for the website....so will one of these sets work for smoothing out rough spots after the first round of stage one? Which grit/grits will help the most?
Diamond Burr Set 30 Piece Set: $12.00 1/8" Shaft 36, 80, 120, 220 or 400 grit #100-30
Or this one: Diamond Carving Tool Set 50 Piece, $28.00 1/8" Shaft 36, 80, 120, 220 or 400 grit #200-50
Post by deb193redux on Jul 30, 2013 8:57:58 GMT -5
If you want to remove material (accelerated and directed course grind) then you want a course burr. The finer girts are for smoothing without hardly removing any material. IMO this should only be done to fix small pitts or to broaden the valley of a crevasse or to take off small protrusions. IF you use it to remove a 1/4" wedge on one end, you will eat through plated burrs like crazy.
Also keep spraying work with water. Always grind silica wet.
