Post by sheltie on Aug 3, 2013 13:32:05 GMT -5
Our Lortone QT6 has taken to stopping for no apparent reason. It is not overweight and the motor runs well. All it takes is a push by hand and it will start and run for awhile. Could it be the drive shaft needs to be replaced or some other possibility?
Steve
Member since June 2005
Post by Steve on Aug 3, 2013 13:34:27 GMT -5
Check the belt. It may have stretched.
Post by Drummond Island Rocks on Aug 3, 2013 14:40:20 GMT -5
I had an old lortone 3 pounder that was doing that and even did it with a new belt with proper tension. I used to have to tip the machine so that all the weight went to the drive shaft to keep it turning. I know that's not a great answer but it kept ours rolling. All you can do is make sure your belt is good and your shafts are oiled and spinning freely.
Post by deb193redux on Aug 3, 2013 15:50:16 GMT -5
if belt is not slipping, lube any bushings, make sure pulley is not slipping on shaft. if pulley is not slipping, otherwise motor is getting weak. lubrication and tightening up everything should do it though
QT6 Stops
Aug 3, 2013 21:24:50 GMT -5
via mobile
Post by orrum on Aug 3, 2013 21:24:50 GMT -5
My Skilcraft rotary tumbler has to be tilted to run too Chuck.
rollingstone
Member since July 2009
Post by rollingstone on Aug 3, 2013 22:13:49 GMT -5
If the drive shaft is still turning and the barrel is just not catching then it may just be that the barrel has gotten slick and needs to be roughened up slightly with a file or wood rasp. If the drive shaft itself is not turning then do the belt tightening etc.
unclesoska
Member since February 2011
Post by unclesoska on Aug 4, 2013 11:29:15 GMT -5
I had the same problem with my QT-12... Turned out the belt was slipping.
herchenx
Member since January 2012
Post by herchenx on Aug 4, 2013 14:04:07 GMT -5
My qt was slipping on the roller itself, hit it with sandpaper and it worked again
Sent from my phone.
panamark
Member since September 2012
Post by panamark on Aug 5, 2013 22:45:55 GMT -5
My OLD Lortone was doing that periodically. The old motor had just lost it's power and it could only do a 1/2 load. Tried most of the suggestions, but finally had to break down and buy a new motor from the Rockshed. Installed and the problem went away permanently. Or at least for several years I hope.
