nancy5591
Member since August 2013
Post by nancy5591 on Aug 26, 2013 21:04:49 GMT -5
New AR12 Thumler Tumbler & idler shaft repeatedly stops spinning. Any suggestions or help would be appreciated. This is my first attempt.
Post by jakesrocks on Aug 26, 2013 21:34:04 GMT -5
First check the belt. Make sure no oil is on the belt and pulleys. A little rubbing alcohol on a cotton swab will clean them. A drop or 2 of light oil on each bearing might help too. Use 3 in 1 oil or sewing machine oil. If neither of those do it, either your belt is worn, or you have too heavy of a load in the barrel.
