Post by kap on Sept 23, 2013 19:56:05 GMT -5
My Link belt that drives the feed broke on my 20" HP does anyone know where I can buy a new Link Belt? I had a spare I thought but it is too short. Thanks!
Post by Drummond Island Rocks on Sept 23, 2013 20:09:04 GMT -5
Post by kap on Sept 23, 2013 20:31:12 GMT -5
Mine locks together with 2 pins on each link but I dont see why that one would not work. THANKS!!!
Tousled Owl
Member since August 2011
Post by Tousled Owl on Sept 24, 2013 12:44:16 GMT -5
I made use of that kind of thing to get an arbor going with some expanding drums a little while back. Works well, and I didn't have to disassemble the arbor to replace the belt. Doesn't seem to slip and not contributing any particular vibration that I can tell. I don't have a huge amount of run time on it so far, but looks like it will hold up OK.
However, it was no small challenge to assemble (mine came as three discrete sections because I didn't have the wits to check an obvious source of supply like HF (D'OH!)) and I had to resort to some vocabulary I hadn't used since the last time I spent an hour trying to get a chain saw started. So if you get into modifying the length, keep that in mind.
That said, I am less than swift about all manner of mechanical adventures, so it may be a piece of cake for someone handier.
Post by kap on Sept 25, 2013 16:14:25 GMT -5
Went to a industrial supply store and picked up some and put back on cutting again!!
Post by johnjsgems on Sept 26, 2013 19:52:12 GMT -5
Wouldn't a standard V-belt be easy to install? I know I changed the drive belt on my HP24 but can't remember if arbor belt was easy or not.
Post by quartz on Oct 2, 2013 23:19:56 GMT -5
Shop cleaning the other day, found 9 left over links of the link belt as pictured in the HF ad link above, got it at McGuire Bearing. If someone can use it, PM me an address, better than tossing it.
