Post by jamesp on Sept 24, 2013 13:00:40 GMT -5
Started out ight yellow/brown. From a 10 foot circle higher above water line than most. Pieces from over a dozen corals. Go figure. Learned a lesson. Do NOT cook wet coral. The big piece was in wet clay and the small one is basically river gravel at this site. Both very wet and both fractured heavily. Probably will take at least a month in the greenhouse. Will put close to the wood stove to assist drying. Nice purple color,hmmmm
Post by Drummond Island Rocks on Sept 25, 2013 7:08:41 GMT -5
those have perfect color. They sure do tumble nice but I am really starting to like the cabs even better. Need to slab more and stop hitting them all with that darn ratchet-hammer.
Post by jamesp on Sept 25, 2013 7:46:20 GMT -5
Still experimenting Chuck. Just bought a load back. The water finally dropped. But i can't cook the wetter ones because they shatter.Gotta let them dry or precook at 200. Still learning. LOL.
Post by Deleted on Sept 25, 2013 13:13:57 GMT -5
+1 to pre-cook at 200F - do NOT let it boil though.
Post by Fossilman on Sept 25, 2013 13:23:42 GMT -5
Awesome James.............Coral is some cool stuff!
Post by jamesp on Sept 25, 2013 21:14:24 GMT -5
Well thats's the deal. 212 will boil and burst-duh. That's why they precook at 200. I is much dryer w/the kitchen convection oven w/high air circulation. Kitchen oven is rough on sex life. Out in the dog house where it's safe.
Post by Deleted on Sept 25, 2013 22:45:28 GMT -5
YOU KNEW THAT! HAHA
Post by jamesp on Sept 26, 2013 6:44:04 GMT -5
Damage by boiling or damage to sex life or both. Never even thought about the boil -duuuuhhhhh.
Initial colors are variable and electric. Dried a load last nite. Starting the warm uo this morning. I chipped them into tumbles.
That way they can be dried (at 200!) and cooked.
I had to weld a new table in the oven. It needed a heat conduction isolator. The bottom of the containers were way too hot so a shield and an air gap should solve that. Like an electric burner tends to burn food at bottom of pot...
grayfingers
Member since November 2007
Post by grayfingers on Sept 26, 2013 7:47:00 GMT -5
Post by jamesp on Sept 26, 2013 10:59:45 GMT -5
My Dad was squadron Commander for the fighter jet pilots on the USS Coral Sea. You close Bill. I am the man.
Post by Deleted on Sept 26, 2013 18:10:37 GMT -5
Jim are those the same heaters used in electric water heaters?
If not, can the electric water heaters be run dry?
Post by jamesp on Sept 26, 2013 18:51:35 GMT -5
I think electric water heaters will self destruct in air. They are exactly like your kitchen oven, but lower wattage. That's right. Kitchen oven is 2000 watts +. This oven is 1000 watts. At least thats what my research came up with. It did not make sense to me.
But a dry water heater does not nessecarily burn the element does it? I would use ones designed for air. End of story.
Post by pghram on Sept 28, 2013 11:28:27 GMT -5
Beautiful batch of coral. Will you also cook the purple or have you already cooked it?
Rich
Post by Deleted on Sept 28, 2013 14:07:26 GMT -5
If that new stuff was closer to the surface and already cooked color is it possible that there could have been one hell of a fire there at some point in time? Beautiful stuff. Jim
Post by jamesp on Sept 28, 2013 19:34:22 GMT -5
I have found out some weird stuff heating this stuff. 1- hotter oven takes it to new colors. But to a point, higher than 600F and you risk fractures 2-got to let it dry or heat and hold at 200 to dry it out. coral from the water or wet soil will fracture terribly. 6 hours at 200F and it is ready to cook 3-this surprised me. I pulled the load out 2 days ago and was not pleased. I looked at it yesterday and thought it had gotten a deeper color. Today my 15 pounds of lite lavender chips are rich lavender. Yesterday i put the deeper colored lavender from another load next to it and sure enough it is changing.
Jim, this stuff is 20 feet in the ground and is only exposed because the river washed the soil away. It is possible fire got to it but pretty unlikely. Cause it is in a river valley. But one never knows what the past has done.
The 15 pounds of purple is cooked and a great success Rich. I am very happy about that. However i do not think i was very successful at finding the coral that turns purple on last week's trip. That bothers me. I did find some new stuff. I will post some more soon.
