geodehunter
Member since October 2013
Post by geodehunter on Oct 8, 2013 14:06:29 GMT -5
In between grits do you guy's actually take the bowl off of the drive unit to clean it. I can't seem to find any info on this. Any help would be greatly appreciated. Thanks, Robbie
Thunder69
Thunder 2000-2015
Post by Thunder69 on Oct 8, 2013 16:36:00 GMT -5
Robbie..Yes you want to do it..Makes it a lot easier to get your rocks out and you are not dealing with the machine itself..I take a scotch brite pad and clean the bowl and rinse it out well ..I also use a hose with a high pressure nozzle on it to clean the rocks and bowl...John
Post by 150FromFundy on Oct 8, 2013 17:21:19 GMT -5
I go one step further and burnish with borax between grit/polish changes in my UV-10. The borax should remove any residue from the grit/polish as well as that greasy floating film (HDPE dust) that is scraped of the inside of the bowl.
Most vibe users will have a dedicated bowl for the polish stage. It's virtually impossible get all the grit off the foam pad on the inside of the lid, so a dedicated polish bowl will reduce the possibility of cross contamination in the final stage.
Good luck.
Darryl.
Post by Hard Rock Cafe on Oct 8, 2013 18:09:37 GMT -5
Yes, take the bowl off and empty it. Kind of a pain, I know, but you need to do it.
I don't scrub my UV18 to the degree that other posters do since the grit breaks down so rapidly in a vibe. I just rinse it out and wash off the lid. I do have a dedicated polish bowl.
geodehunter
Post by geodehunter on Oct 9, 2013 14:13:31 GMT -5
Thanks for all the help guy's I really appreciate it. Looks like I need to put another bowl on the wish list.
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Oct 27, 2013 14:30:27 GMT -5
of course nobody mentioned the easiest way to do it..................
Just buy a second tumbler and use it for polish only ... that way you never have to clean the bowl out thusly eliminating the need to disassemble the tumbler to clean the bowl... as a matter aof fact... if you have 3 tumblers you are even better off as there are 3 stages to a vibe tumbler... rough sand, & polish!!
there the lazy mans approach to vibe tumbling!!!!
and of course there are the piggyback vibe tumblers.. but that's another story ......
