Post by jamesp on Oct 30, 2013 21:11:14 GMT -5
Post by Deleted on Oct 30, 2013 21:14:14 GMT -5
dig-it brutha. dig-it.
Now make 100 of them and have them wrapped for sale. World class stones. Very cool.
Dood you max the potential from those bad boys. MAX.
Post by jamesp on Oct 30, 2013 21:20:16 GMT -5
You need to visit the spot that i collect these at. A heavenly spot and 2 creek party hole used by the ancients. On the Suwanee River. Thanks
Post by pghram on Oct 31, 2013 9:04:00 GMT -5
Beautiful cab.
Rich
Post by Donnie's Rocky Treasures on Nov 1, 2013 8:12:15 GMT -5
Wow, looking real good! Nice color & pattern!
juzwuz
Member since April 2010
Post by juzwuz on Nov 1, 2013 14:22:46 GMT -5
how fast does that diamond cup spin?
Post by Deleted on Nov 1, 2013 14:52:33 GMT -5
The diamond cups that I have used chip the hell out of things but mine do not have the solid center like yours. Jim
Post by Drummond Island Rocks on Nov 1, 2013 14:57:01 GMT -5
You have mastered getting the perfect amount of grind to show just enough of the skin. Hard to believe you accomplish that with an angle grinder.
Post by Deleted on Nov 1, 2013 17:55:19 GMT -5
It is hard to believe that James gets anything done because it seems like he is doing a hundred things at one time. But by damn he seems to get more done than ten of us put together. Jim
grizman
Member since July 2011
Post by grizman on Nov 1, 2013 17:57:00 GMT -5
Very obviously, where there is a will there is a way. All your work paid off on that project. It is definitely a beaut!
Post by Tonyterner on Nov 1, 2013 18:43:09 GMT -5
Wow that's a beautiful cab and a process that works well. Nice job!
Post by Rockoonz on Nov 1, 2013 21:57:10 GMT -5
Very nice. Nice the way you have the cleats on your wheel ground concave like the old timer cabbers did with their SiC wheels.
Lee
Post by jamesp on Nov 2, 2013 12:09:31 GMT -5
That diamond wheel is going 3600. The skin on those pebbles runs deep often time. Yes that wheel chips.But i use that to my advantage. Because i want to remove a lot of material fast(look at what that stone started as). Often 50% reduction. As long as it does not FRACTURE. The coral does well on that wheel. Probably shatter many other materials. That concave wear was not by choice Lee. It comes in handy though. I want to slow the system down. So i got a bigger wheel out of China. On Aliexpress. Will try to spin this at about 400-500 RPM. I may solder bridges in between the cleats as Lee so well called them. Or China calls them segments. Check it out, no way OSHA exists in China. This heavy sucker would kill you on a standard 3 HP nine inch grinder. I will gear it down Steroidal diamonds
Post by jamesp on Nov 2, 2013 12:20:46 GMT -5
Post by pghram on Nov 4, 2013 10:26:02 GMT -5
I hope you dop, that looks hard on the fingers.
Rich
