Post by Deleted on Nov 19, 2013 12:49:09 GMT -5
I have been thinking about alll these huge tumbler barrels you guys have. How do you clean them out between grits and the end?
Post by Hard Rock Cafe on Nov 19, 2013 13:13:38 GMT -5
My big barrel is a back breaker when it's full. I could really use an engine hoist to lift it. Otherwise it's the same process I use for any barrel. I just dump it onto a set of stacked screens on a bucket: quarter inch hardware cloth in a frame above window screen in a frame. The screens make washing and culling a lot easier.
I only use my rotaries for rough grind. Sanding and polishing is done in a vibe.
Post by Deleted on Nov 19, 2013 13:19:14 GMT -5
Thanks Chuck. I wonder also what jamesp does...
Post by jamesp on Nov 19, 2013 13:31:19 GMT -5
Post by Deleted on Nov 19, 2013 14:16:59 GMT -5
basically what I envisioned. Thanks to both of you gentlemen.
Pros both of you.
Post by jamesp on Nov 19, 2013 15:09:36 GMT -5
i am for sure
Post by Hard Rock Cafe on Nov 19, 2013 16:25:55 GMT -5
You're welcome, Scott! I like to catch the fines that fall through the hardware cloth to use as filler in either the grind or vibe. Cheaper than ceramics! LOL @ James
herchenx
Member since January 2012
Post by herchenx on Nov 19, 2013 17:11:42 GMT -5
I just crack the bottom of my barrel while it is still tumbling and let it drain all over the motor and floor.
Post by jamesp on Nov 19, 2013 17:34:07 GMT -5
not good for the motor. well, John asked for appalachian engineering. you get what you ask for.
letting the barrel drain like that is as good as app engineering can get
Post by Deleted on Nov 19, 2013 17:52:58 GMT -5
I just crack the bottom of my barrel while it is still tumbling and let it drain all over the motor and floor. Thank you John. That really and truly made me laugh out loud! Thank you.
Post by jamesp on Nov 19, 2013 18:37:01 GMT -5
John was probably not laughing the day it ground up all his rocks. i had a 2 month old load ground so nice. 65 pounds. gas pushed the cap off partially and allowed the fluid to drain and beat the stew out of the rocks. They 'were' beauties. I walked out of the house and heard them way over just rattling away and knew i was in trouble. Better if the cap comes off and dumps the rocks. But a full load running dry leaves fractures that are very hard to tumble off.
Post by Deleted on Nov 19, 2013 19:50:49 GMT -5
John was probably not laughing the day it ground up all his rocks. Of course not, but today his self deprecating sense of humor really tickled my fancy.
herchenx
Post by herchenx on Nov 19, 2013 21:15:05 GMT -5
Glad I could give a chuckle!
panamark
Member since September 2012
Post by panamark on Nov 19, 2013 22:01:46 GMT -5
John was probably not laughing the day it ground up all his rocks. i had a 2 month old load ground so nice. 65 pounds. gas pushed the cap off partially and allowed the fluid to drain and beat the stew out of the rocks. They 'were' beauties. I walked out of the house and heard them way over just rattling away and knew i was in trouble. Yeah, it is never a good thing to see someone running towards their tumbler. Been there, done that too many times ![(freaked)](//storage.proboards.com/1258779/images/YmrWJeZhnPYbaUHcPpYN.gif) . John, ( herchenx)* I love that you still have a sense of humor. I guess it has been long enough in the grieving process huh. Anyway, like Scott I actually did laugh out loud. Thanks, I needed that today! * when you do this username link, do they actually get a notice in their profile? Easier than quoting sometimes yet lets em know.
Post by quartz on Nov 19, 2013 23:22:57 GMT -5
My big barrels run 100# full, one for roughing. I handtruck the barrel out back, crack it, and let it drain into a deep hole to get most of the snot and some weight out of it. Then I bring it back and set it on a 5' countertop high table under the edge of our patio cover. The table has a freebee ss sink in it, and we run water from an outside faucet, or off the utility room sink in cold weather, warm water that way. The sink drain goes thru a couple buckets for settling purposes, then into a big gravel filled hole off the patio a ways. I put the hole under the perimeter drain, if it gets full of water the drain takes it away.
Post by jamesp on Nov 19, 2013 23:52:59 GMT -5
better to laugh than to cry. let's hope it does not happen again.
Post by jamesp on Nov 19, 2013 23:53:34 GMT -5
I know Larry has something to say on this one.
Post by quartz on Nov 20, 2013 0:27:40 GMT -5
Yup, I've had a mess or two myself. Had a little gas buildup. ![](http://farm3.staticflickr.com/2873/10956566423_44744bb788_c.jpg)
Post by jamesp on Nov 20, 2013 0:46:38 GMT -5
It amazes me how much grit can get on the pillar blocks. My motor finally got bad bearings though.
herchenx
Post by herchenx on Nov 20, 2013 1:09:11 GMT -5
John, ( herchenx)* I love that you still have a sense of humor. I guess it has been long enough in the grieving process huh. Anyway, like Scott I actually did laugh out loud. Thanks, I needed that today! * when you do this username link, do they actually get a notice in their profile? Easier than quoting sometimes yet lets em know. In the Android app there is no notification; but on the desktop version of the site there is a notification under profile that you tagged me; so yes!
