Post by sheltie on Nov 25, 2013 14:33:14 GMT -5
Ok, I finally got the Sony a350 and took a couple of pictures. The setting is AUTO, I used a tripod with a remote switch. Two pics, one with black background, the other with white, both in light box using florescent lights on both sides and top. What, if anything, is next?
Post by Deleted on Nov 25, 2013 15:02:07 GMT -5
I dunno, looks pretty good doesn't it?!?!?!
I am not sure of the color of the stone, except it is VERY consistent between the two images. Would you say the color is correctly represented?
My gut says it's slightly overexposed, but you tell me.
Post by sheltie on Nov 25, 2013 16:59:41 GMT -5
If it isn't right on, it's VERY close. Looks like I ought to keep the current settings?
Post by sheltie on Nov 25, 2013 17:08:24 GMT -5
dupe
panamark
Member since September 2012
Post by panamark on Nov 25, 2013 19:16:07 GMT -5
Just a thought, but one good test is to shoot a picture of a color wheel&pattern instead of a rock. Then you can see how it is doing across the entire spectrum by comparing it onscreen to what the real wheel is as you hold in your hand. I think you can probably find a color wheel on line to print on a good color printer and then use as the baseline. Hope this helps.
Post by sheltie on Nov 25, 2013 19:29:25 GMT -5
The key words are "good color printer". Mine is old but adequate (funny, that's what my wife says about me!)for my needs. I'll see if I can get a color wheel someplace.
Post by Pat on Nov 25, 2013 21:19:42 GMT -5
Compared to the black background, the slab on white looks a little washed out, and the background looks pink.
Check and set your white balance (WB) before you click the button.
If you have Photoshop ($$) or Photoshop Elements ($), you can make adjustments quickly.
Turn off all lights in the room that are not being used for your photo. Is your fluorescent bulb a daylight bulb? Daylight bulbs are desirable.
You'll get there!
Post by Deleted on Nov 25, 2013 21:21:12 GMT -5
An open pack of skittles is a good substitute for a color wheel. Everybody knows what they look like. (In the 1980's we used lifesavers!)
Post by Woodyrock on Nov 26, 2013 3:02:26 GMT -5
The old standard for setting exposure balance was an 18% reflective grey card. Grey background will give you a more neutral exposure.
Woody
Post by sheltie on Nov 26, 2013 9:11:12 GMT -5
I bought a set of white balance cards, but I forgot how to use them! I didn't have much luck with them on my cheap camera but it might work on the good one if I could remember how they are supposed to be used.
