Post by Drummond Island Rocks on Nov 25, 2013 19:47:23 GMT -5
I have always used the mk303 6"x.032 blades in my trim saw and am completely happy with the performance but I go through them pretty quick. I would like to know if the MK301 would perform the same and maybe last longer?. The price difference is about $20 so I guess I would like to know that its worth $20 more.
I might even switch from water and rv antifreeze to oil to see if that makes a significant difference.
as always thanks for any advice Chuck
Post by deb193redux on Nov 25, 2013 23:26:57 GMT -5
in 12" the 301 is thicker than the 303
Post by Drummond Island Rocks on Nov 26, 2013 7:07:41 GMT -5
Daniel- I was checking them out and the 6" Mk301 is listed at .025 thick so its actually going to be thinner then the Mk303 blades I have been using. I think I'll probably bite the bullet and give it a try.
Post by deb193redux on Nov 26, 2013 10:13:06 GMT -5
good luck. likely wont be worse anyway, and may suite your style
LarryS
SoCal desert rats
Member since August 2010
Post by LarryS on Nov 26, 2013 11:27:51 GMT -5
I have both in 10" and the 301 is a much better blade. Takes less sharpening and less force to push hard agate by hand. Power feed motor runs cooler. The 301 is a bit louder than the 303. I can't hear the 303 and the 301 sounds like my tile saw. I think it's worth the extra bucks.
Post by Drummond Island Rocks on Nov 26, 2013 11:31:25 GMT -5
