Post by jamesp on Dec 1, 2013 8:45:37 GMT -5
I found this on a new member's profile.
GeorgeStoneStore
Post by GeorgeStoneStore on Dec 1, 2013 9:35:01 GMT -5
thank's for sharing pic It is a simple structure, one of the first cutter. ( study ) - 3000 rpm - 400 W (0.5 hp) - 200 mm (8 ") saw blade - Linear slide and vise the machine box is wooden (plywood) Angle iron legs Now I this machine working:
Post by jamesp on Dec 1, 2013 10:43:38 GMT -5
Did you build this saw George ?
GeorgeStoneStore
Post by GeorgeStoneStore on Dec 1, 2013 11:13:31 GMT -5
Yes, made 2012 Since then I've built a few saw machine and grinding machine ( orders ) This saw: -1650 rpm 1hp (750W) -10" saw blade - High precision driving (linear bearing) I am planning a 16 " machine. Soon start to produce components I there are many large stone collected. small saw - large stone, not working
Post by jamesp on Dec 1, 2013 11:32:22 GMT -5
Linear bearing on right side is good. All on one side. Very well made machine. Thanks
GeorgeStoneStore
Post by GeorgeStoneStore on Dec 1, 2013 11:39:57 GMT -5
I thank you
Post by Deleted on Dec 1, 2013 14:17:11 GMT -5
Nice work! I like the vice design.
panamark
Member since September 2012
Post by panamark on Dec 1, 2013 20:32:56 GMT -5
George,do you have to re-vice the rock each time? I see you have an adjustment mechanism on the vice, but it looks like it is maxed out right there.
Post by 1dave on Dec 1, 2013 20:44:55 GMT -5
George,do you have to re-vice the rock each time? I see you have an adjustment mechanism on the vice, but it looks like it is maxed out right there. I see a nut and slot at the front of the vice, slid as close to the blade as it can get in the last photo. Not sure on the photo just above it.
GeorgeStoneStore
Post by GeorgeStoneStore on Dec 2, 2013 1:01:24 GMT -5
Yes, it is possible correction. Unfortunately, only design flaw... move slightly to the right and to the left. only one or two slices can be cut mostly half Nodule can be cut, but it quickly. 1 min / 1" of course it depends on the size of the stone.
