HeefageLA
Member since October 2013
Post by HeefageLA on Jan 1, 2014 9:38:17 GMT -5
Doing my first tumble and its pretty muddy inside the barrel.
Whats the easiest way to separate the sludge and grit?
blessed
Member since January 2010
Post by blessed on Jan 1, 2014 10:26:22 GMT -5
I would say you are using too much grit or not letting it run long enough. The grit should be completely broke down. What brand of tumbler do you have? I know this did not answer the question you asked. I have never tried to separate it.
James
Post by jamesp on Jan 1, 2014 10:55:07 GMT -5
After 5-12 days depending on conditions your grit should be reduced completely to mud. If you see a few grit particles they could be stuck in the corners at the lid.
Typically all the grit should wear to mud at all the same time.
If you run w/too much water or too much rock the grit may not break down properly.
HeefageLA
Post by HeefageLA on Jan 1, 2014 11:00:05 GMT -5
I have an ar-12. This is my first time polishing so many mistakes are to be made.
Post by pghram on Jan 1, 2014 19:37:20 GMT -5
Lots of mud=good grinding, so wash it out & recharg w/ clean water & new grit. In other words, rinse & repeat.
Rich
Post by jamesp on Jan 1, 2014 19:45:15 GMT -5
yep. it takes fresh grit to get ur done.
