Post by 1dave on Jan 8, 2014 13:04:50 GMT -5
I wanted some copper solder to play with. Rio Grande had the best price, but a full pound was more than I wanted at $27. I checked out www.rawtreasures.com/Bought 5 feet for $3.75 FREE SHIPPING! To quote Arnold, "I'll be back!"
Post by Deleted on Jan 8, 2014 13:05:31 GMT -5
$27 a pound! is there silver in it?
Post by rockjunquie on Jan 8, 2014 13:20:57 GMT -5
I use the stuff from rawtreasures. It's really good. A great color match. I did a lot of research a while back and found these people had the best reputation for color match.
Post by 1dave on Jan 8, 2014 13:42:42 GMT -5
$27 a pound! is there silver in it? No.
Post by Deleted on Jan 8, 2014 14:01:59 GMT -5
OMG $27 lb for 8% phosphorus??
I found $20 for bronze (adds tin), but that seems to be the going rate. That's a lot of profit built in.
Love to see the braze results.
amyk
I'm a slabber, I'm a cabber, I'm a midnight wrapper.
Member since January 2010
Post by amyk on Jan 8, 2014 23:10:28 GMT -5
Thats the same copper solder i bought. Let me know if it melts OK for you. it doesn't work for me.
Amy
Post by rockjunquie on Jan 9, 2014 8:52:16 GMT -5
amyk, this is the first solder I ever used. I love to solder with it. I don't use any flux at all with my copper to copper soldering and I have never had a problem. It melts fine. I've done way more copper soldering than silver because I have found it easier to do. I haven't done big pieces, though.
Post by connrock on Jan 9, 2014 11:04:17 GMT -5
You're no good Dave,,,, I just ordered some too! I've never tried it so why not give it a go? Thanks,,, connrock
Post by 1dave on Jan 9, 2014 14:23:05 GMT -5
You're no good Dave,,,, I just ordered some too! I've never tried it so why not give it a go? Thanks,,, connrock I know it is no excuse, but it hasn't arrived yet. I haven't lit my torch since trying to solder with German Silver Bezel Wire! I was going to go ahead with soft solder, then thought "Why not keep it all copper?" Thus the purchase.
Post by deb193redux on Jan 9, 2014 14:59:12 GMT -5
the flow temp is high but it does work well
Tom
Post by Tom on Jan 9, 2014 15:10:46 GMT -5
Amy, I have both the color match and the not color match from Rio, both melt fine and work for me. You must be heat sinking your heat away. i bet when you get the charcoal block it will be much better
Post by rockjunquie on Jan 9, 2014 16:45:41 GMT -5
Amy, I have both the color match and the not color match from Rio, both melt fine and work for me. You must be heat sinking your heat away. i bet when you get the charcoal block it will be much better YES! The charcoal is a micro torche's bestest friend.
Post by radio on Jan 9, 2014 18:09:24 GMT -5
I buy a lot of my base metals from Monsterslayer. Copper solder was about 10 cents a foot the last I bought 3 or 4 months ago The wife makes a lot of Chaine Maille and MS is usually cheaper on wire, etc. than Ring lord
Post by 1dave on Jan 9, 2014 18:39:27 GMT -5
Post by radio on Jan 9, 2014 18:44:31 GMT -5
Thunderbird supply has a good selection of native American stamps. Not all are on the website so it pays to call. They will also have a custom stamp made for you. A unique feature of their stamps is whoever hand makes them uses push rods, intake and exhaust valves and a host of other re purposed materials. They are hardened and hold up quite well
amyk
Post by amyk on Jan 10, 2014 0:52:31 GMT -5
How can the torch not be hot enough to melt the solder if it is melting the metal?
Tom
Post by Tom on Jan 10, 2014 8:17:09 GMT -5
Hi Amy, do you have a picture of how you are set up to solder. All I can think of is that the way you are set up the heat is being drawn away from the solder but not the bezel wire.
Is it just the bezel wire that is melting? Is the base plate melting? Have you just put a piece of solder on something to see if you can melt it?
If you have some larger (14 gauge) copper wire file the ends very flat and roll it into a circle, don't worry if its not perfect. The put a piece of the solder on the joint and try that. your micro torch won't melt the copper I don't think, while they say 2500F I bet that is best case.
Several things you can try to experiment, I feel your frustration and we want this to work for you. When will your charcoal block be delivered? I really think that will make a big difference
Hang in there
