Post by jamesp on Jan 21, 2014 12:19:13 GMT -5
They are already nicely rounded. This would take 2 months at 30/60. They were sharp and hammer chipped before pre grind. Lavic jaspers-fine stuff Larry(Quartz) wood from Oregon(focus bad) Zephyr Hills Fl. coral Black Bay Fl. coral Suwanee River Fl. small corals Withlacoochee River Ga. bluish coral that was on Youtube chipping video Also Withlacoochee Also Withla Also Withla
Post by Drummond Island Rocks on Jan 21, 2014 12:21:24 GMT -5
looks like time well spent. those are going to be great when polished.
Post by jamesp on Jan 21, 2014 12:59:36 GMT -5
looks like time well spent. those are going to be great when polished. Chuck To heck with all that waiting Chuck. And electricity, wear etc. 2-3 hours grinding on 15 pounds and they have great shape. Kinda do not tumble unless pre shaped any more.
Post by Drummond Island Rocks on Jan 21, 2014 13:15:58 GMT -5
if you add up how much time it takes each week to sort the rocks and re charge the barrels during 30/60 you are probably ahead of the game at 3 hours labor for hand grinding.
Post by jamesp on Jan 21, 2014 15:01:25 GMT -5
if you add up how much time it takes each week to sort the rocks and re charge the barrels during 30/60 you are probably ahead of the game at 3 hours labor for hand grinding. Chuck The tumbler is on a second power meter in the nursery. I rarely run anything in the winter except the tumblers. Base electrical charge is $20. Bill is $60 w/the 1/8 and 1/3 HP going and $50 for just the 1/3 HP. So $30 for electricity for the 4 barrel tumbler alone. Then recharge with 30/60 every 4-5 days is 5 cups six times a month. The grit kicks my tail. The grinding wheel cost $20 and does not want to wear out. Guessing 400 pounds of tumbles has been run on it. Grinding the rind off can cut the weight by half on the thick rinded coral. And i am sorry, but the labor is a problem. It takes me a good 2 hours easy to do the refresh and more if cherry picking. The pre grind takes a little longer than a 4 barrel refresh. Pre grind is the way to go hands down. It almost stops any need for cherry picking too. And everyone should remove those that are ready. I know Chuck does it. I will run these for another 4-5 day charge. So 10 days max. After 5 days i could not find a single bring mark from the 30 grit grinder... And closer to round/oval stones seem to grind very efficiently.
Post by Drummond Island Rocks on Jan 21, 2014 15:06:47 GMT -5
Thats the way to go for you warm weather folks. I'm thinking thats an outside chore and its 3 degrees here at the moment. I spend no less then 2 hours doing my grit changes and rock inspections every Saturday (for about 40 pounds of rock) so your estimate is right on.
chuck
Post by pghram on Jan 21, 2014 15:47:11 GMT -5
Looking good, patience is over-rated sometimes.
Rich
Post by jamesp on Jan 21, 2014 17:31:40 GMT -5
Thats the way to go for you warm weather folks. I'm thinking thats an outside chore and its 3 degrees here at the moment. I spend no less then 2 hours doing my grit changes and rock inspections every Saturday (for about 40 pounds of rock) so your estimate is right on. chuck I do not dilly dally around. I am well organized and in a dirty greenhouse and it still is a big job. And when that grit is worn i change it. If it is worn to 220 or 150 it ain't gonna round your rocks. Get a fresh charge of coarse in that thing. Even here my fingers are numb. I go about 30 minutes at a time and come in to thaw out. Sometimes i wait 10 days to allow my skin to grow back.LOL.
Post by jamesp on Jan 21, 2014 17:33:58 GMT -5
Looking good, patience is over-rated sometimes. Rich Get ur done. Whatever it takes Rich. You guys cold enough. That 4F cooked a giant grove of black bamboo. It will loose all it's leaves. That's cold!
Post by pghram on Jan 21, 2014 22:52:13 GMT -5
I'm originally from Pgh PA, so not that cold, I suffer more from the heat & humidity. Will the banboo come back?
Rich
Post by quartz on Jan 21, 2014 23:33:36 GMT -5
Nice show, like all the variety. Where does the Lavic jasper come from, read about it several times but never seen origin? That is nice mtl.
Post by 1dave on Jan 21, 2014 23:42:20 GMT -5
Nice show, like all the variety. Where does the Lavic jasper come from, read about it several times but never seen origin? That is nice mtl. Scott (Shotgunner) just got a batch on his Caddy mt. trip.
carloscinco
Member since July 2008
Post by carloscinco on Jan 22, 2014 6:10:15 GMT -5
It ain't a horse race but you don't want it to be a tortoise race. That's looking really sweet!
Post by jamesp on Jan 22, 2014 8:23:32 GMT -5
It ain't a horse race but you don't want it to be a tortoise race. That's looking really sweet! Thanks for the pre grind idea Carlos.
Post by jamesp on Jan 22, 2014 8:29:02 GMT -5
I'm originally from Pgh PA, so not that cold, I suffer more from the heat & humidity. Will the banboo come back? Rich I have a couple of bamboos that will take the cold of Pitts. Yellow Groove(aureasulcata) and i can't remember . It will not kill them. But the leaves will fall off and it will look bad. The roots are very hard to kill. salt or goats for several years
bsky4463
Member since September 2013
Post by bsky4463 on Jan 22, 2014 9:08:40 GMT -5
Nice showing James....as said before it is also a good way preserve the maximum amount of material by focusing the grind on the problem areas. When the glacier recedes I will definitely be employing this tactic on some of my tumble stock. Cheers.
Post by jamesp on Jan 22, 2014 9:51:40 GMT -5
Nice showing James....as said before it is also a good way preserve the maximum amount of material by focusing the grind on the problem areas. When the glacier recedes I will definitely be employing this tactic on some of my tumble stock. Cheers. It is 12F here this morning w/wind. I relate to waiting for warm weather. I think Montucky has sent their weather my way.
kaldorlon
Member since October 2013
Post by kaldorlon on Jan 22, 2014 12:35:44 GMT -5
Was suppose to go up to my buddies rock shed today...but the cold has us waiting a few more days!
Post by jamesp on Jan 22, 2014 14:03:22 GMT -5
Was suppose to go up to my buddies rock shed today...but the cold has us waiting a few more days! What was your coldest up in Chattanooga John?
Post by Deleted on Jan 22, 2014 17:29:11 GMT -5
Nice show, like all the variety. Where does the Lavic jasper come from, read about it several times but never seen origin? That is nice mtl. Scott (Shotgunner) just got a batch on his Caddy mt. trip. So I guess it comes from me! Lavic Jasper is named for the location. Way back when, the railroad named "sidings" throughout the desert routes. They made funny names "Zzyzzx" "Siberia" "Cadiz" "Lavic" and johnjsgems will know more I am sure. The area is sparsely covered with palm sized pieces of colorful and highly varied jaspers. You actually park on jaspers when you get to the main site. Here are some pix of stuff similar to the lavic that Jim started with. As you can see it is highly variable.
