Post by phil on Jan 27, 2014 16:18:03 GMT -5
Hi all, I'm refurbing an old RayTech GemKing 4 station polisher. So far I've been able to find everything but the water control valves that go by each wheel. Yes, I could use needle valves like used in swamp coolers and other 1/4 inch copper line, but I'd like to find some that will front mount using a black plastic control knob. They are inline valves, so the water can pass thru to the next wheel, as needed. And I can't find anything even close.
If I have to use the needle valves, I'll have to mount the line and everything externally, and kluge up all sorts of extra parts to make it work. It will work, but look kinda hokey.
Has anyone else had this problem, did you find a good solution, do you know where to buy similar valves?
GemKing has something similar, but they want $25 PER assy!
Thanks! Phil
lparker
Member since March 2008
Post by lparker on Jan 27, 2014 17:24:16 GMT -5
Try an aquarium supply store for valves
Post by Deleted on Jan 27, 2014 18:02:05 GMT -5
if no local fish store is easy, lowes and home depot sell them for swamp coolers.
Post by phil on Jan 27, 2014 22:38:38 GMT -5
Thanks. Those L valves are what I'm trying to get away from. I need in line, pass thru valves.
Post by phil on Jan 27, 2014 23:04:49 GMT -5
Here's a pic of the old one. The knob and needle are missing, but I think you'll get the idea. Thanks!
Post by quartz on Jan 27, 2014 23:14:58 GMT -5
Might also try a farm supply that handles spray equipment, all sorts of valves and fittings on that stuff.
jollyrockhound
Member since March 2013
Post by jollyrockhound on Jan 28, 2014 12:09:31 GMT -5
if no local fish store is easy, lowes and home depot sell them for swamp coolers. I use ice maker lines adapted to pex fittings. This way I can use a valve such as for sink supply or toilets. Shotgunner nailed it they are awesome for stuff.
Post by phil on Jan 28, 2014 18:06:14 GMT -5
Tried 3 local pet/fish stores today, close but not adaptable. Only thing at Lows and HD are the brass needle valves, which, as I said, I can adapt to if I have to but I'd rather retrofit a little nice looking result. I'll have to external mount all the tubing, fittings, etc if I go that way. Will try Ranchers Supply later this week. Thanks all
QuailRiver
Post by QuailRiver on Jan 28, 2014 18:43:09 GMT -5
Phil, Have you checked to see if Raytech still has any of those valves in old-stock that they may have kept to sell as replacement parts? If they don't still have any in stock, maybe they can let you talk to someone whose worked there long enough to remember who the supply manufacturer of those valves were. Larry C.
Post by phil on Jan 28, 2014 19:10:43 GMT -5
Thanks, and yes. Raytech today is not the Raytech that was. They said they don't have any plans, specs, tech sheets, anything on the old equipment they no longer sell. Pretty much didn't really want to talk to me unless it involved their current lines.
Daniel Green
Member since April 2009
Post by Daniel Green on Jan 28, 2014 21:02:39 GMT -5
augusto
Member since January 2014
Post by augusto on Jan 29, 2014 2:54:43 GMT -5
Google "Diverter Needle Valves" and click image. You will see lots of pics. The pics are linked to the web page.
Post by phil on Jan 29, 2014 12:45:45 GMT -5
Thanks. I've done that, also gang valves, inline valves, and a few others. Will keep looking!
Post by phil on Jan 29, 2014 19:14:14 GMT -5
WOO HOO! I've been checking online everyday, doing different words for many searches. Tried some new wording today, and I was just able to find 5 originals from one person, and a single from another! So I bought them all! Plus I was able to find a used multi that I can scavenge for parts to make the original 4 singles work, so I'll have enough for my friends unit that he wants rehabbed too! Blind squirrel finds a nut! Thanks everyone! Phil
jollyrockhound
Post by jollyrockhound on Jan 29, 2014 23:54:45 GMT -5
Glad it worked out for ya.
