jjdub
Member since December 2013
Post by jjdub on Jan 29, 2014 18:39:29 GMT -5
Anyone have experience using one of the combo flat lap/saw machines. I've seen a couple that were made by Craftsman (made in the 60's or 70's ?) with a drip water feed. While I'm all about efficiency, I don't see how the 10" saw blade sitting horizontal in a recessed bath would be much use.
Post by Drummond Island Rocks on Jan 29, 2014 19:44:21 GMT -5
Those units make great flat laps if the bearings are still good but I have never seen one being used for the saw portion these days. Most I run across are missing the vise assembly. The blade is not submerged it just has a water drip feed keeping it cool and the vise gets pulled toward the blade by gravity via a rope with weights attached.
LarryS
SoCal desert rats
Member since August 2010
Post by LarryS on Jan 29, 2014 19:46:28 GMT -5
Covington still makes a 8" & 10" combo model.
jjdub
Post by jjdub on Jan 29, 2014 23:10:34 GMT -5
Those units make great flat laps if the bearings are still good but I have never seen one being used for the saw portion these days. Most I run across are missing the vise assembly. The blade is not submerged it just has a water drip feed keeping it cool and the vise gets pulled toward the blade by gravity via a rope with weights attached. Chuck Thanks. Maybe I'll snag one and use it as an inexpensive flat lap. If the bearings are shot I can replace them, assuming they aren't some exotic size.
QuailRiver
Post by QuailRiver on Jan 30, 2014 1:56:01 GMT -5
The ones sold with the Craftsman name were made by B&I industries in Wisconsin and had a cast aluminum housing, drip pot and vise. They were made in both a 6" and 10" model which both used laps with the standard 1/2" diameter arbor holes. The 10" model came with 8" laps and a 10" blade. You are right about the trim saw function not being very good on those. But as far as flat laps go they are very good and are nearly indestructible. The B&I units use bronze sleeve bearings and a grease cup. The bearings are very easy and inexpensive to replace. I still use a B&I 10" model to do my final polishing of cabs when I polish with oxides. Being a horizontal lap recessed within the oblong housing isn't nearly as messy as trying to polish with oxides on a vertical mounted lap. There were thousands of the B&I units sold over about a 30 year period and they can be picked up inexpensively on eBay, Craigslist and at estate sales. The Covington flat lap has an aluminum or white metal housing, a plastic drip pot, a steel drip pot mount, and uses permanently sealed insert bearings. Covington has made flat lap units with both 1/2" and 5/8" arbors. So their flat lap units with the 5/8" arbor can not use the standard 1/2" arbor hole laps. So you either have to buy the 5/8" arbor hole laps from Covington or bore out the arbor hole to 5/8" on standard laps. IMO the Covington saw vise is a little better than the B&I saw vise but both are very messy to use for sawing and are limited to small rocks. I don't like either brand for trimming slabs. But both make good flat laps for cabbing and polishing with the right laps. Larry C.
jjdub
Post by jjdub on Jan 30, 2014 13:11:03 GMT -5
Larry - thanks for the info and insight. I like the idea of the old style bronze sleeve bearings and grease cup.
