bamananu
Member since December 2011
Post by bamananu on Feb 2, 2014 18:05:37 GMT -5
I have 2 out-of-warranty double barreled Chicago Electric (Harbor Freight)Rotary Tumblers that I need to replace the drum boot gaskets on. Does anyone know where to order gaskets that will fit them? I hate to throw out machines that are working just fine other than needing new gaskets. I have a friend that needs replace the barrel nut on her CE tumbler. Any help there would be appreciated as well.
MrCoffee
Member since December 2005
Post by MrCoffee on Feb 2, 2014 19:58:00 GMT -5
If I am not mistaken, I believe the barrels on a CE tumbler are an exact clone of the Lortone 3 pound barrels. You can find gaskets and nuts that will fit easily on EBay. Any Lortone knurled nut will do. The gasket from a Lortone 3 pound barrel (like you find on a Lortone 3A-NR) should fit the barrels of your CE tumblers. Wish you the best.
blessed
Member since January 2010
Post by blessed on Feb 2, 2014 22:32:37 GMT -5
The barrels on a CE tumbler is not a exact clone, they are similar. These parts for a Lortone 33B will work on a CE barrel, # 210-02 belt, #240-10 boot gasket,# 020-01 inner lid. The CE inner lid has metric threads, the Lortone has standard threads, 1/4 x 20. Any good hardware store will have a metric nut that will fit the CE inner lid. I am running three CE doubles with all Lortone parts, including 33B motor and bushings.
I buy all my parts from The Rock Shed.
I hope this will help. James
bamananu
Post by bamananu on Feb 2, 2014 23:39:10 GMT -5
Wonderful...thanks so very much!!
Post by pghram on Feb 3, 2014 10:43:19 GMT -5
The Rech Shed is great. Kingsley North is good too.
Rich
