Post by jamesp on Feb 7, 2014 6:50:02 GMT -5
Post by Drummond Island Rocks on Feb 7, 2014 7:21:21 GMT -5
those shots look great James. For tumbles I usually do like you are doing and hand hold in front of a bulb but for thinner items like cabs I use a nifty little lexan tracing light box my wife had for another craft/hobby. here's a couple shots of cabs with it forum.rocktumblinghobby.com/thread/64037/1-28And this is pretty much what it is. Its a frosted white lexan box with a bulb in it. Chuck
grayfingers
Member since November 2007
Post by grayfingers on Feb 7, 2014 7:42:21 GMT -5
James, I sometimes put a brooder light with a flood lamp in a box with a hole cut for the cord. I set a glass platter from a microwave over it, and tissue or paper over the glass. Then I light from above too.
Post by jamesp on Feb 7, 2014 11:21:17 GMT -5
Post by pghram on Feb 7, 2014 11:42:04 GMT -5
James, Here is a before & after comparison of an agate cab. Rich
Post by Drummond Island Rocks on Feb 7, 2014 11:42:20 GMT -5
Here's a better shot of the one my wife is letting me borrow from her craft area. If you google "embossing light box" they will come up. Not sure if its bright enough for thick tumbles but it works nice on cabs. Chuck
Post by pghram on Feb 7, 2014 11:44:16 GMT -5
Grayfingers,
That produced oustanding results, thanks for sharing you process.
Rich
Post by jamesp on Feb 7, 2014 11:59:59 GMT -5
Did this real quick in the sun light. It still looks oranger than it's purple ish color. Is not the sun heavy w/orange colored light? But i think the sun is richest in the orange spectrum. There are all different colored stars. The hottest being white to blue, the coldest being red. The middle being yellow. Am i talking greek? Do i need to try a 6000K real hot white bulb maybe? I want to have a strong pure white source that penetrates.
Post by jamesp on Feb 7, 2014 12:14:22 GMT -5
Here is a before & after comparison of an agate cab. Read more: forum.rocktumblinghobby.com/thread/64213/photograph-backlit-translucent-rocks#ixzz2semmLC2XRich, try holding other colored translucent agates like you did there in the sun like lavender, purple, red if you have such, to see if you have a strong orange color component. It may be that the color is derived from iron and the iron goes orange. But i am pretty certain the sun light has a peak in the orange color. Like when you look at the sun(not long please) or a child paints it. It's always orange. The orange is bothering me. But i do not know the science of light color. Only heard enough to put me in a quandary. A pure white light source. Does that exist? Or is the sun a pure white light source? Or are our eyes set at the white balance of sun light? Or am i going wacko .
Post by pghram on Feb 7, 2014 12:30:34 GMT -5
James, I just took a couple of snaps of an amethyst cab for comparison. Rich
gemfeller
Member since June 2011
Post by gemfeller on Feb 7, 2014 13:34:32 GMT -5
A pure white light source. Does that exist? Or is the sun a pure white light source? Or are our eyes set at the white balance of sun light? Or am i going wacko . James, maybe this will help: lowel.com/edu/color_temperature_and_rendering_demystified.htmlIn general midday sunlight has more blue than incandescent light which is strong at the red end of the spectrum. (Sunlight is also reddish at dawn and sunset.) This affects the color of images unless it's compensated for with white-balancing your digital camera or using proper film. I think white light is defined as light perceived by the eye as having the same color as sunlight at noon.
Post by jamesp on Feb 7, 2014 14:00:46 GMT -5
A pure white light source. Does that exist? Or is the sun a pure white light source? Or are our eyes set at the white balance of sun light? Or am i going wacko . James, maybe this will help: lowel.com/edu/color_temperature_and_rendering_demystified.htmlIn general midday sunlight has more blue than incandescent light which is strong at the red end of the spectrum. (Sunlight is also reddish at dawn and sunset.) This affects the color of images unless it's compensated for with white-balancing your digital camera or using proper film. I think white light is defined as light perceived by the eye as having the same color as sunlight at noon. This is part of the subject i wanted to get into. I apologize for going full circle to get there. The definition of white light. Noon light w/blue sky back ground. And then noon sun on an overcast day.....what impact is that?
Post by jamesp on Feb 7, 2014 14:03:43 GMT -5
I have noticed Tela, Chuck and George have very white photos. I see Chuck's curly Q fluorescent bulb through the reflection in his dang shiny rocks. George posted a piece of petrified wood that is dead white. Hungarians have abnormally large brains and are very smart I believe he said they are fluorescent 23 watt 6500K bulbs. It was my favorite photo. Here it is: quote author=" GeorgeStoneStore" source="/post/724372/thread" timestamp="1391354296"]sample photo, shot Sony HX100V. petrified wood , from Hungary. Location: Megyaszó, Zemplén Mts ( light source, two compact fluorescent lamp, 6500K, 23W, camera tripod, self timer) [/quote]
unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on Feb 7, 2014 16:57:00 GMT -5
Here is a link to get 5500K flourescent photo bulbs. Regular bulbs are to warm a color temperature temperature causing a redish tint. These bulbs will provide the light to get accurate colors without the need for filter correction. They have a 10,000 hour lefe and use lettle eectric and produce leittle heat Stu
Post by jamesp on Feb 7, 2014 17:42:52 GMT -5
Here is a link to get 5500K flourescent photo bulbs. Regular bulbs are to warm a color temperature temperature causing a redish tint. These bulbs will provide the light to get accurate colors without the need for filter correction. They have a 10,000 hour lefe and use lettle eectric and produce leittle heat Stu Did you forget the link Stu ?
Post by jamesp on Feb 7, 2014 18:24:34 GMT -5
James, I just took a couple of snaps of an amethyst cab for comparison. Rich The sun made a great photo of that amethyst Rich. No orange or yellow. Must be a color issue once light passes thru the coral. The agate cab looks about what color it should be w/light passing thru it. Being whisker colored. Nice pieces.
