Post by 1dave on Feb 9, 2014 12:18:44 GMT -5
jamesp, I disagree with his premises and conclusions, but the information is interesting.
www.skepticalscience.com/Earths-five-mass-extinction-events.html
When CO2 concentration rises, precipitation increases.
So colored corals are formed in cooler water?
What caused these mass extinctions? To find the major driver of coral extinction, Veron 2008 looks at the possible options and eliminates many as the primary cause. A meteorite strike is capable of creating huge dust clouds that lead to devastating darkness and cold. However, if this were the cause of coral reef extinction, 99% of the world's coral species would be wiped out in weeks or months. The fossil record shows coral extinction occurred over much longer periods.
Warmer temperatures cause mass bleaching of corals. However, even in a warmer world, deep ocean temperatures would still remain well below surface temperatures and there would be safe havens where cooler water upwells from the deep ocean. That's not to say meteorites or global warming played no part in coral extinction - both have been contributing factors at various times. But they cannot fully explain the nature of coral extinctions as observed in the fossil record.
What Veron 2008 found was each mass extinction event corresponded to periods of quickly changing atmospheric CO2. When CO2 changes slowly, the gradual increase allows mixing and buffering of surface layers by deep ocean sinks. Marine organisms also have time to adapt to the new environmental conditions. However, when CO2 increases abruptly, the acidification effects are intensified in shallow waters owing to a lack of mixing. It also gives marine life little time to adapt.
So rate of change is a key variable in nature's ability to adapt. The current rate of change in CO2 levels has no known precedent. Oceans don't respond instantly to a CO2 build-up, so the full effects of acidification take decades to centuries to develop. This means we will have irretrievably committed the Earth to the acidification process long before its effects become anywhere near as obvious as those of mass bleaching today. If we continue business-as-usual CO2 emissions, ocean pH will eventually drop to a point at which a host of other chemical changes such as anoxia (an absence of oxygen) are expected. If this happens, the state of the oceans at the end Cretaceous 65 million years ago will become a reality and the Earth will enter the sixth mass extinction.
