jjdub
Member since December 2013
Post by jjdub on Feb 12, 2014 15:31:13 GMT -5
I just took my (new to me) UV 18 out of the box. The previous owner ran two loads of jewelry in walnut shells, otherwise this thing is brand spankin' new.
Anyway, is there supposed to be a layer of foam attached to the lid? I never noticed this in various tumbler pics, so I just wanted to make sure this wasn't something added by the previous owner. It's just a black foam layer attached to the underside of the lid to (presumably) create a better seal between the tub and lid.
Thanks in advance from a newbie!
Steve
Member since June 2005
Post by Steve on Feb 13, 2014 13:02:43 GMT -5
Quick Answer -- YES
Slightly longer answer: since the foam is black and fairly thin and dense it will not show up in pictures. It really helps cut down on the noise.
Steve
Post by 150FromFundy on Feb 21, 2014 19:41:02 GMT -5
Steve is right, but it will still be noisy. Be sure to clean the foam well between loads. The down side of the foam is that it tends to catch and hold grit which can lead to contamination between stages.
Darryl.
