Post by Sabre52 on Feb 22, 2014 13:24:51 GMT -5
Howdy folks, I mentioned the other day that I've been having a tough time with my final polish. Well, I corrected the problem by simply running the polish stage ten days in the UV-10 in Rockshed AO. This is weird because for years I've run only 4-5 days in this polish and achieved a very fine shine. Still confused as to exactly what the problem is but I'm wondering if the AO in this last batch of polish is a little coarser than it has been in the past so the longer run is necessary to break it down. Have any of you noticed this problem? Nothing else in my process has been changed for as long as I've used Rockshed AO polish. Anyway, 10 days got me a really nice mirror polish on this load of mixed agate and jasper. Here's a pic of the whole lot. Notice I used a huge amount of smalls too.....Mel
Post by Drummond Island Rocks on Feb 22, 2014 14:16:30 GMT -5
you got a nice shine on those now. I cant help with the Rockshed A/O polish. I ordered 5 pounds from there over a year ago when I was using rotaries and then I switched to the lot-o shortly after so at 1/2 teaspoon per week I may have 10 years of running non-stop before I need more polish.
Jynx
Member since January 2014
Finally!
Feb 22, 2014 15:41:22 GMT -5
via mobile
Post by Jynx on Feb 22, 2014 15:41:22 GMT -5
So many gorgeous stones! The orange one at the bottom is my favorite though. I've had a little bit of a hard time with my ao from therockshed on picture jasper, but everything else has shined up beautifully (except the lighter pieces of amazonite I've done recently)
tkvancil
Member since September 2011
Post by tkvancil on Feb 22, 2014 16:15:14 GMT -5
Persistence paid off ! Nice bunch of shine there. The AO I'm using now was purchased last year so I can't help there either. Hopefully it hasn't changed, I'm getting low. If I had to double my rotary time I'd be waiting a month for polish.
Post by Sabre52 on Feb 22, 2014 19:27:50 GMT -5
I ran back through my notes and noticed I had changed one thing I forgot. I was having trouble with the 110/220 eating up my UV-10 barrels too fast and making holes in the bottoms so, I had cut that run down to three days instead of my usual 5-7. Figure it could be that the 110/220 had not broken down enough to prep my rocks for prepolish and that the scratches left by the fine grind were too deep for the prepolish to remove properly. I used to run a 500 stage so did not have to worry about that but hopefully that was part of my problem too and can be fixed.
You know, when you get older it's good to take notes so's you kin remember what ya done but its even better if'n you remember to read the damn notes...Mel
Post by Deleted on Feb 22, 2014 19:35:47 GMT -5
good on you for keeping notes.
Nice work Senor Mel.
timloco
Member since April 2012
Post by timloco on Feb 22, 2014 20:03:26 GMT -5
Those turned out nice... I just switched to the UV-10 for everything but the initial stage and I'm real happy with it. Still learning though. Good call on taking notes,I need to do that.
Thunder69
Thunder 2000-2015
Post by Thunder69 on Feb 22, 2014 20:03:32 GMT -5
Nice ones Mel...I found that with my vibe that if I do a couple tsp.of borax in with the polish, it makes it shine faster...John
Post by roy on Feb 22, 2014 20:44:02 GMT -5
nice shine mel !
Post by pghram on Feb 22, 2014 22:53:36 GMT -5
Beautiful batch.
Rich
carloscinco
Member since July 2008
Post by carloscinco on Feb 23, 2014 19:44:05 GMT -5
Looks like you nailed the solution 'cause those look sweet!
jollyrockhound
Member since March 2013
Post by jollyrockhound on Feb 25, 2014 13:01:14 GMT -5
Nice looking batch of shineys
riverrock
Member since April 2010
Post by riverrock on Feb 25, 2014 15:26:40 GMT -5
I like the batch. One day I will start to take notes . I have being using my very foggy mine to keep records. I like the size of the material and the shine .
