mikeinsjc
Member since June 2010
Post by mikeinsjc on Mar 7, 2014 23:01:58 GMT -5
Does anyone make a small high-pressure washer for cleaning grit from rock between tumbling steps?
Post by deb193redux on Mar 7, 2014 23:13:50 GMT -5
lparker
Member since March 2008
Post by lparker on Mar 8, 2014 9:19:25 GMT -5
I've one. Be absolutely sure to wear safety glasses when using one and at the least neoprene gloves - and it still stings smartly when that stream hits me hand. You can get one at just about any screen printing supply co.
tafinami
Member since January 2018
Post by tafinami on Jan 11, 2018 5:44:19 GMT -5
hmmm, probably a good point with the safety. Probably a lot easier to slice off a finger than a rock........... Not much fun unless its hands on though. That might be the point that kills it for me. Always someone who has to go and ruin a bad idea. And I do not have cabin fever, your just all out to get me and my rocks!!!! What was I talking about? I should go outside probably. pressurewasherify.com/blog/best-pressure-washer-cars-reviews/
Wooferhound
Lortone QT66 and 3A
Member since December 2016
Post by Wooferhound on Jan 11, 2018 7:48:51 GMT -5
They make water sprayers for dental cleaning that might not cut your fingers.
Post by fantastic5 on Jan 11, 2018 13:06:28 GMT -5
I have a Textile gun that I use to clean self collected crystals with. I'm sure it would clean grit as well.
Post by jamesp on Jan 12, 2018 15:51:05 GMT -5
An small inexpensive 110VAC pressure washer with a short barrel re-fitted on the gun works well. They run at lower pressures, smaller hoses. Bigger spray tip way reduces spray force to safer levels (like chemical applicator tips).
