Post by Deleted on Mar 16, 2014 17:29:09 GMT -5
I didn't see any problems , nothing major or any buldging from the barrel.....I burped it, do I need to worry about gas build up any more or just let her roll?
Post by Deleted on Mar 16, 2014 17:31:16 GMT -5
3-4 days into coarse btw
tkvancil
Member since September 2011
Post by tkvancil on Mar 16, 2014 18:00:22 GMT -5
Me personally ... I rarely ever open a barrel until the end of the run. I'd just keep an eye on it and watch for any bulging, burp it if it starts to swell otherwise let it roll. I let my rocks sit in hot tap water and add hot tap water to the barrel before I begin the run if I anticipate any gas problem. A little borax seems to help as well. There is a discussion here about gas build up if your interested ... forum.rocktumblinghobby.com/post/713478/thread
Post by Deleted on Mar 16, 2014 18:05:11 GMT -5
that's why I held off, but I just wanted to avoid any mess, for begginers its 12 hours into, part was probally curiosity and the other anal side I wanted to follow the rule book I got..thanks for the post I will read, I think I can rest easy without any worrys till this cycle is over
Post by Deleted on Mar 16, 2014 18:27:47 GMT -5
it might be in my head but the little bit of water from the paper towel I cleaned off the seals made some bubbles go away and now that its running I hear a bit more action, I think its good I did open it up its not as muffled now sound wise
SirRoxalot
Member since October 2003
Post by SirRoxalot on Mar 16, 2014 19:34:00 GMT -5
Don't worry about foam.
Here's the secret to tumbling:
Let the barrel spin and forget about it.
Recharge every seven or ten and you'll be fine.
It really is a no brainer, there's nothing complicated.
Post by pghram on Mar 17, 2014 8:29:12 GMT -5
I agree, let it roll, unless you see any bulging.
Rich
