Post by Deleted on Mar 22, 2014 16:22:22 GMT -5
The time is up for this round, Im still in coarse, but sure its gonna need more time in coarse......I was wanting to just chunk in some more grit and let it go.....but its a new fresh batch of grit, the old grit is the last of the stuff I got months ago........so my question is even though its not necessary ive been told...would it be a good idea to rinse all rocks off and clean out barrel incase the two grits don't like eachother? I am starting to understand most gas build up comes from the organics in the rocks....but could the new grit not like the old grit and give me a problem?
herchenx
Member since January 2012
Post by herchenx on Mar 22, 2014 16:31:04 GMT -5
No grit is grit as long as it is the same coarseness and the same material (generally Silicon Carbide)
If you are just keeping on with coarse grit just get the slurry rinsed out and re run, if the level of rock in your barrel is less than 3/4 full top that off first.
herchenx
Post by herchenx on Mar 22, 2014 16:32:59 GMT -5
Oh also, just in case no one has told you, never rinse slurry or grit into any drain in your house or apartment. The slurry can harden into cement in the pipes.
Make sure grit doesn't end up in your washer either as it can wreck bearings and wear out seals.
Post by Deleted on Mar 22, 2014 16:33:10 GMT -5
thanks buddy
Post by Deleted on Mar 22, 2014 16:39:21 GMT -5
Oh I always dispose of all old slurry in old milk jugs so im good there, but thanks again=]
