Post by Fossilman on Mar 23, 2014 16:20:13 GMT -5
I have a couple of old electric motors,one is 1/4 HP 5.4 amp with a 1725 RPM...If I rewired the cord,greased it up (yes,it runs) would it make a good buffer for polishing rocks..(To fast-to slow???) I'm thinking the other motor is the same on everything,both have grinding wheels on them,look to be from the 50's or 60's... What I like,is both are USA made!
Post by Deleted on Mar 23, 2014 16:23:24 GMT -5
Should work.i adopted one about 2 yrs ago.1/4 hp .1725 rpm.it has a 7" rocks lapidary aluminum buffer on it.works like a charm.
Post by Fossilman on Mar 23, 2014 18:27:21 GMT -5
Cool,I will replace the power cord and oil it up-put on a good buffin' wheel............Thanks for the info...
Post by mohs on Mar 24, 2014 12:21:34 GMT -5
run them till the windings toast then run them some more mostly
Post by johnjsgems on Mar 24, 2014 16:38:16 GMT -5
It would run a small arbor or trim saw. Same speed as the Genie so you should be happy.
