moogie
Member since December 2013
Post by moogie on Mar 24, 2014 20:38:14 GMT -5
I'm using my 6 pound Lortone rotating tumbler for the first time. I have a mix of rocks that are about Mohs 6 to 7. I didn't have enough to fill 2/3 full as in the directions, so I added fresh ceramic media to make up the 2/3. I started it yesterday, popped the top just now to see how things were progressing, and all I see is a vat of gray whipped cream! Is this the gas build up? Should I let it all go flat before restarting? I'm afraid to let it sit too long, I had a bad experience with my vibrating tumbler where it all turned to basically solid wet cement. I took a couple of rocks out, and they seem to be nicely covered with grit, so I guess that's positive. Anyway, should I be concerned, or just keep popping the top every day to let the gas escape?
moogie
Post by moogie on Mar 24, 2014 21:07:43 GMT -5
HA,well never mind, Sheree's post just popped up about the same problem, and I'll try those ideas.
Post by jamesp on Mar 24, 2014 21:17:22 GMT -5
HA,well never mind, Sheree's post just popped up about the same problem, and I'll try those ideas. Good timing
mrbouldersmash
Member since March 2014
Post by mrbouldersmash on Mar 27, 2014 20:59:01 GMT -5
get some beach pebbles or nut's/nut shells, they stsand up to quite a bashing with great results
mrbouldersmash
Post by mrbouldersmash on Mar 27, 2014 21:00:00 GMT -5
take up pottery
