Post by mrbrett on May 4, 2004 11:36:15 GMT -5
what is a good way to keep the mist down on your slab saw. I have a plexiglass hood that allows the mist to escape from the bottom. I do wear a resporater but like to get it under control. ( we need spell check on this site)
Post by stoner on May 4, 2004 12:17:20 GMT -5
Hey Brett. Do you have an old box fan or vacuum motor? Maybe you could rig up sort of a dust/mist collector using 1" or 2" foam and cover it with polyester material as a filter. Just a thought. And I guess I'd better think about that in my design. I'm gonna start building it soon. Thanks again for the pics, they helped alot.
later, Ed
Post by Noosh9057 on May 4, 2004 13:06:30 GMT -5
YES SPELL CHECK WOULD BE GREAT!!!!!!!!
Post by sandsman1 on May 4, 2004 20:43:21 GMT -5
how about a boat bilge blower motor when i had a larger boat ti had a blower motor in it to suck out all the gas fumes out of the bilge befor starting so it didnt blow up hahaha but there cheap and have an opening from 3 to 4 inch wide that could be cut into the side of saw and mounted and im sure fitted with a small filter box to catch mist maybe even on the inside of the saw so it dosent hafta travel through the blower there cheap enuff when on sale only prob i can see is there 12 volt but a smaill converter or battery charger would be enuff to run one since there not gonna run 24/7 only when cutting ok seeya---john
Post by rockyraccoon on May 7, 2004 23:18:31 GMT -5
Post by sandsman1 on May 8, 2004 22:16:49 GMT -5
hi all ---hey kim i gotta small 10inch slab saw and it dont mistup too much but i have a light next to it and once and awile i see the mist coming from under the see through lid i think that might work for me since its not realy alot ----great find kim thanks --seeya john
Post by rockyraccoon on May 8, 2004 22:35:01 GMT -5
let me know if it works. i just happened across it while looking for a dressing stick for my blade.
kim
Post by creativeminded on May 10, 2004 14:24:29 GMT -5
Great site thanks. Tami
Post by mrbrett on May 11, 2004 8:23:26 GMT -5
a dressing stick for your blade? I read that using a plain ole' red brick does a great job of getting a blade sharp again. Is that what you are going to do?
Post by rockyraccoon on May 11, 2004 9:11:30 GMT -5
this was explained to me over the phone when i purchased my blade but i couldn't possibly explain it to another person so here's what i found that will basically explain what i was told about the dressing stick and the reasons for it. my blade is actually flat on the edges and not "sharp". i have a mk lapidary blade. www.ukam.com/dressing_sticks.htmi wouldn't think slicing into a brick would expose the diamonds but instead further the glazing over process. kim
