unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on May 8, 2014 19:59:42 GMT -5
I just got my Foredom tools and I started setting them up. I got the TX5400 carvers set a DP30 Drill Press and an EM dial controll as well as the foot speed contrl. I also got the mini vise for the drill press. I just realized that I got the zink metal mini vise and they also have a plastic version. As I will be drilling into stone with water should I have gotten the plastic vise instead of the zinc metal vise? I got all of the tools from a seller on Ebay Ronsrocks. His prices were lower than Otto Frei and everything was shipped direct from Foredom, really fast service. I originally wanted to get the Foredom from John over at Johnsgems but he is no longer a Foredom dealer. However I will be getting my slab saw from him. Thanks Stu
blackout5783
Post by blackout5783 on May 8, 2014 20:12:36 GMT -5
I would guess you're probably OK with the zinc vise. It's used as a protective coating on steel sometimes, so it must be at least better than that. I would be concerned about cracking a plastic vise. If you want to be on the safe side, take it out of the water when you're done and give it a shot of WD40.
unclestu
Post by unclestu on May 8, 2014 20:16:58 GMT -5
Great idea WD40. I think that shuld do it. Thanks for the good idea Stu
