unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on May 19, 2014 11:27:20 GMT -5
I just ordered a complete set of new 6" Galaxy and Nova wheels for my Kingsley cab machine. This is the machine that I have: www.kingsleynorth.com/skshop/product.php?id=95532&catID=1059I lost the owners manual and never changed wheels before. Does anyone know how to do this? Also would I need some sort of bushing for the new wheels. I had the Nova wheels put on before they shipped the cab machine when I first purchased it a few years ago. Thanks Stu
Post by deb193redux on May 19, 2014 12:13:57 GMT -5
when the end screw is removes, the wheels and spacers just pull off. you will need the plastic bushings if the wheel hole is larger than the shaft. if you can't reuse ones you have, telescoping bushings are pretty common form lapidary and diamond wheel suppliers.
unclestu
Post by unclestu on May 19, 2014 12:41:04 GMT -5
Thanks so much for the quick reply. I am glad that I don't have to take the whole thing apart I guess I would just do the same procedure on both the right and left side of the machine. I think the shaft is 3/4" on my machine and I think the hole in the wheels is 1" so I will have to order some bushing in case the existing ones can't be reused. I know this is a dumb question but when I order bushings, what size should I order if the shaft on my machine is 3/4"? Thanks Stu
Post by catmandewe on May 19, 2014 14:14:58 GMT -5
You can order the bushings from Diamond Pacific and each bushing set comes with all the sizes. I think they are $2 each. It will probably cost more for shipping than for bushings. You should be able to reuse your bushings though.
Tony
blackout5783
Post by blackout5783 on May 19, 2014 17:18:40 GMT -5
One quick note about the bushings. Make sure they run the entire width of the wheel hub on the shaft. Use 2 side by side if necessary. Using only one that's too small and trying to center it in the wheel hub guarantees a visit to wobble city.
Post by jakesrocks on May 19, 2014 17:23:26 GMT -5
Stu, don't forget that the left end has left hand threads.
