Post by jamesp on May 25, 2014 12:03:43 GMT -5
These were attached side by side. Sawed simultaneously. About 1.5 inches across. Colors glitter when viewing angle is changed. Photo lacks showing internal reflections.
Post by Fossilman on May 25, 2014 14:36:20 GMT -5
Totally awesome James..That's a two thumbs up!
Post by jamesp on May 25, 2014 14:45:44 GMT -5
Totally awesome James..That's a two thumbs up! If I cooked that it would be chocolate colored as it has a rich color and it has saw oil in it.
Post by Sabre52 on May 25, 2014 15:16:20 GMT -5
Man oh man James, that one is outrageous. What a great polyp pattern.....Mel
Post by snowmom on May 25, 2014 17:15:33 GMT -5
just dazzling! solid sunshine!
Post by jamesp on May 25, 2014 17:27:06 GMT -5
just dazzling! solid sunshine! Thanks snowmom.
Post by rockpickerforever on May 25, 2014 17:30:32 GMT -5
Looks like pineapple!! (But don't try to eat it!)
Post by jamesp on May 25, 2014 17:40:27 GMT -5
I had a Bull Terrier that chewed rocks Jean. His teeth were worn to the gums. Never could break him from the habit. That was a OCD X10 canine.
Post by radio on May 25, 2014 18:01:22 GMT -5
Oooooo! Dat's purdy!!! if it were a bit smaller it would make an incredible pendant! Does it have a Brother, Sister or Cousin that came from a smaller section?
Post by jamesp on May 25, 2014 23:09:41 GMT -5
Oooooo! Dat's purdy!!! if it were a bit smaller it would make an incredible pendant! Does it have a Brother, Sister or Cousin that came from a smaller section? The whole piece was about 5 inches long. So it produced a good many little slabs. They were all about the same quality. Would make cool cabs if color line was followed.
Post by quartz on May 25, 2014 23:19:40 GMT -5
Purdy stuff, seems you always find a little better than the previous, thanks. Larry
Post by Tommy on May 26, 2014 9:40:09 GMT -5
Really beautiful stuff James! I know you said it would turn chocolate brown if cooked - would that ruin it or would it still dazzle?
Post by jamesp on May 27, 2014 6:46:24 GMT -5
Really beautiful stuff James! I know you said it would turn chocolate brown if cooked - would that ruin it or would it still dazzle? Yes, it should have dazzle, but the saw oil turns brown well before 600F. The solution would be to heat it whole before sawn. In that situation the yellow would turn orange most likely. The coral requires a high 600F. A lot of agates from out your way can be cooked at 350F-400F. Easy to do in a counter top toaster oven. You should try some of those fine materials you find.
Post by pghram on May 27, 2014 15:37:39 GMT -5
Beautiful!!!
Rich
