Post by jamesp on Jun 7, 2014 13:02:47 GMT -5
We are bad about leaving junk in the yard. To get rid of it bamboo is often grown to cover it up. I had been looking for the 4 and 6 foot fiberglass planters and finally found them when cutting this grove back w/a saw blade equipped weed eater. And had no idea where I stashed the giganticus tire(tar). This is Psuedosasa Japonica commonly called arrow bamboo. Give ya $50 if you can walk thru it.
Post by snowmom on Jun 9, 2014 5:00:44 GMT -5
not taking that bet! That stuff is really pretty. Bamboo shoots for stir fry shouldn't be hard to find at your house!
Post by Deleted on Jun 9, 2014 9:21:09 GMT -5
Bamboo shoots for stir fry shouldn't be hard to find at your house! Yes, but, it seems, only in May if you require fresh.
panamark
Member since September 2012
Post by panamark on Jun 9, 2014 10:30:37 GMT -5
Can I use a flame thrower to help?
Post by jamesp on Jun 9, 2014 11:08:25 GMT -5
>Give ya $50 if you can walk thru it. Can I use a flame thrower to help? Not that easy Mark. After burning, it leaves sharp pun gee spikes sticking up. And not if, but when you trip on them you fall into them. And become a giant shish kabob w/carbonofried spikes emanating from flesh.
Post by jamesp on Jun 9, 2014 11:14:16 GMT -5
not taking that bet! That stuff is really pretty. Bamboo shoots for stir fry shouldn't be hard to find at your house! Scott is right. The bamboo is about done shooting fresh shoots snowmom. Here is a little basket full from 4 weeks ago. Come on down in May and we will fill you truck up. I need to sell to the markets here in Atlanta. Funny, that thin Japonica in the photo above is not known for it's shoots. It is the sweetest on the farm out of 40 bamboos. About the only one that that can be eaten raw w/out making you sick. And it is late and can be harvested now.
Post by Pat on Jun 9, 2014 15:32:20 GMT -5
I've never seen fresh bamboo to eat here. It comes in little cans, but I doubt that is as good as fresh.
The cuts you have in the bin resemble fossils!
Post by jamesp on Jun 9, 2014 20:36:03 GMT -5
I've never seen fresh bamboo to eat here. It comes in little cans, but I doubt that is as good as fresh. The cuts you have in the bin resemble fossils! You know that bamboo is just a large grass Pat. It has a great flavor but really needs to be cooked hard. One of the sweetest bamboo's is P. Dulcis. P. Dulcis Bamboo-Gal Pot Commonly called Sweetshoot Bamboo for its tasty shoots early in the season. It is among the most beautiful with its masses of large drooping leaves, thick culms and a white ring at each node. It is very quick growing and gets very thick for its height, up to 3 inches in diameter at 30 feet in height. It is hardy to minus 10 F.
Post by phil on Jun 9, 2014 20:43:21 GMT -5
I've never seen fresh bamboo to eat here. It comes in little cans, but I doubt that is as good as fresh. The cuts you have in the bin resemble fossils! You know that bamboo is just a large grass Pat. It has a great flavor but really needs to be cooked hard. One of the sweetest bamboo's is P. Dulcis. P. Dulcis Bamboo-Gal Pot Commonly called Sweetshoot Bamboo for its tasty shoots early in the season. It is among the most beautiful with its masses of large drooping leaves, thick culms and a white ring at each node. It is very quick growing and gets very thick for its height, up to 3 inches in diameter at 30 feet in height. It is hardy to minus 10 F. Sounds exactly like what I need for a privacy curtain between me and the dirt lot out back where the gangbangers hang out. Where do I get some and what exactly am I asking for? P. Dulcis Bamboo? Altho 15 feet high would be better, we get winds here in excess of 60 mph every monsoon season... Ideas?
Post by kk on Jun 9, 2014 22:01:48 GMT -5
With heavy shoes and leather gloves, I take the bet if you promise to get rid of the spiders first.
gemfeller
Member since June 2011
Post by gemfeller on Jun 9, 2014 22:31:14 GMT -5
Phil, Can't help you with the bamboo variety but gangbangers? What you need are Punji Sticks.
Post by phil on Jun 9, 2014 23:27:12 GMT -5
Phil, Can't help you with the bamboo variety but gangbangers? What you need are Punji Sticks. True, and broken bamboo becomes very sharp punji sticks.
Post by jamesp on Jun 9, 2014 23:27:49 GMT -5
I can help you Phil. What state do you live in ? Shorter bamboo would be Bissetti,Japonica,solid stem. If you want an impenetrable fence the Psuedosasa Japonica in the above photo is perfect. A great sound barrier too. Let me know. If you see bamboo growing around your area you can dig some clumps and transplant it. That's how I got a lot of mine. And you know that if it looks healthy in your area it will do well at your place.
Post by phil on Jun 9, 2014 23:32:58 GMT -5
Thanks. You don't see much growing around here, and the ones I have seen were kind of puny. We might be too high and dry. I'll ask at the nursery. But I think buying enough root stock to plant along a 30 foot block wall is going to get expensive. Then I've probably got to dig a trench some 24 inches deep and bury more block wall to contain it, right? Or do the roots go deeper to expand?
gemfeller
Post by gemfeller on Jun 9, 2014 23:52:38 GMT -5
Phil, Can't help you with the bamboo variety but gangbangers? What you need are Punji Sticks. True, and broken bamboo becomes very sharp punji sticks. That's why I suggested it.
Post by jamesp on Jun 10, 2014 0:06:23 GMT -5
Yes. ask the nursery. They will know what bamboo is good for your area. The Japonica grove above is 150 feet long. I just keep the perimeter mowed, no barriers. It took four 1 gallon pots and 3 years later it was a wall. I do have natural clay the it thrives in. It does poorly in sand. but other bamboos do well in sand. And many bamboos freeze around 30,20,10,0,-10,-20F, so you really have to ask the nursery. I am mowing some 10 tall Sasa Palmata and Dendrocalimus with the tractor and bush hog. It will come up 3 feet tall next year and then to 5 feet the next. The new leaves and canes will be the richest green for about the next 5 years and lower in height. The 40 HP diesel strains, having to cut the first pass w/mower 2 feet off ground. Takes about 4 passes before it is all mulched to ground level. This also kills the vines and small gums and maples that have sprouted and are 10-15 feet tall. The litter is a foot deep and serves as a mulch so thick that nothing but the bamboo shoots can penetrate it. I wear leather and full cover helmut as shrapnel is flying. Usually wear a full cover motorcycle helmut when working in the groves to avoid eye injuries. Machete cut canes easily puncture the thick tractor tires(punji style). The bush hog has dull blades and shatters the canes rendering them safe to drive over. The 2000 sq ft grove will be beautiful after it shoots next June.
Post by phil on Jun 10, 2014 10:18:20 GMT -5
grin. yeah. and if they break them and impale themselves, I'm no longer liable like I would be if I planted pon-gee sticks like I want to. Thanks!
Post by phil on Jun 10, 2014 22:30:43 GMT -5
Talked to the nursery. Very few boo's grow at this altitude and rainfall. Only one the nursery even carries is black bamboo. They said japonica won't grow here. dang. Guess I'll have to think about pyrocanthia or old fashioned rambling roses or something that has thorns and is very sticky. Thanks!
1nickthegreek
Member since February 2014
Post by 1nickthegreek on Jun 10, 2014 23:26:27 GMT -5
Hey James, do you know if there are any boos that can handle 5K altitude and extreme winters? I would LOVE to quit trying to get trees grown up fast enough for privacy around here in Idaho lol
Post by kk on Jun 11, 2014 1:36:06 GMT -5
Don't know anything about plants, but the pandas live through the snow. So there must be bamboo that can withstand the temperatures.
